Results 1 to 3 of 3
    Montreal, Canada
    450
    Dream comes true
    Hello Everyone, I stop on dreaming and buy the XO-1, now my question is I did not yet unlocked my xmiter to 100mph and try a test run today, I was a bit nervous because the space that I played we're short and a few cars were in the parking lot, as I play with it was different feel from my ERBE to the XO-1, but my question is how would you make it straight all the way, I can't maintain a line, the car were dragging both side. It was out of the box, is it the settings? I read a while ago that someOne said it would be easier to drive it at 50mph above.
    670
    need to get the tires warm your on slicks , plus with the 14 tooth gear you have so much torque that everytime you full throttle it will go sideway just like a real sports car if you just mash the gas with traction control off
    Central, WI.
    215
    Sounds like your car is driving how mine was when I bought it. I had to change the castor and camber. I think I had to give it less toe in. I also have the front tires so they are perfectly square to the ground. Also make sure the foam pad on your steering wheel isn't pushed to far in so it rubs the transmitter. I had a bad wipe out one time when that happened to me.
