+ Reply to Thread
    Anthem Arizona
    362
    Question How do I install venom smart temp fail safe!!!!!
    When ever I plug the throttle servo into the fail safe and plug the false into the receiver I get no throttle. Plz help!!! And btw I have the new traxxas tqi transmitter and reciever
    In a burning building
    8,588
    That's because the TQi already has a built-in fail safe and it does not play well with an external one.
    Anthem Arizona
    362
    Oh so I don't need to put it on
    8,588
    I haven't done research on the TQi since I don't have one but I know that my Duratrax fail-safe would not work with my Traxxas 2.4 Link radio and this was the reason. I would venture to say Traxxas maintained this feature in their next generation of radio(s). It also should say in your truck manual or even the TQi manual.
    One way to check is to turn the electronics on but the engine off and pull to full throttle then turn off the tx. If the throttle goes back to neutral then you should be good.
    Edit: found it all...
    Quote Originally Posted by Jato Manual, page 11
    Always turn your TQi transmitter on first and off last. This procedure will help to prevent your model from receiving stray signals from another transmitter, or other source, and running out of control. Your model has electronic fail-safes to prevent this type of malfunction, but the first, best defense against a runaway model is to always turn the transmitter on first, and off last.
    Quote Originally Posted by page 13
    Automatic Fail-Safe
    The TQi transmitter and receiver are equipped with an automatic fail-safe system that does not require user programming. In the event of signal loss or interference, the throttle will return to neutral and the steering will hold its last commanded position. If Fail-Safe activates while you are operating your model, determine the reason for signal loss and resolve the problem before operating your model again.
    Anthem Arizona
    362
    Yep It has a built in failsafe thx
