Just thought I'd post up my Nitro Pede. Notable mods include: MIP 360 Stinger exhaust, aluminum chassis extension plates, E-Pede suspension and hub conversion with Pro-line Protrac front arms, Roto-Start, and sway bars.
The sway bars made a world of difference and are the best mod I've done on the truck. It pretty much went from being nearly uncontrollable to on rails. It does understeer a bit, but that is way better than flipping over all the time.
The sways are made from .078" music wire. The endlinks are 6-32 threaded rod with a Traxxas rod end on the bottom and a Dubro swivel ball link (#2139) on the top, secured by 3/32" wheel collars. The sways are mounted using 4-40 screws into the wheel collars, and washers (so the sway bar can pivot freely).
The rear one is bent as it is so it clears the shocks (by about 2mm), the exhaust header at full bump (by about 5mm), and the chassis plate at full droop (by about 2mm).
Body on
http://img.photobucket.com/albums/v1...e/133bf0b8.jpg
Body off
http://img.photobucket.com/albums/v1...e/71106b42.jpg
Front sway bar
http://img.photobucket.com/albums/v1...e/adad81da.jpg
Rear sway bar
http://img.photobucket.com/albums/v1...e/379e3853.jpg
it hauls with that pipe and 2.5R on there. thinking of putting the ez start back on to tune it right again then back to pull start. i do see the oil on the rear tire it gets messy when i run it rich only and slips when taking off wheelies like crazy but with that wheel slipping it pulls to one side and flips or runs into a curb/car.
