Results 1 to 4 of 4
    156
    Mamba monster only goes reverse
    I turned on my mamba monster yesterday for the first time and after calibrating, it turns the wheels in reverse, it have center diff forward conversion,
    I'm not sure what's plugged wrong
    May 2010
    Silver Spring, MD
    216
    Try switching the white and black wires.
    RC Turnbuckle Jr. ajb1205's Avatar
    Apr 2007
    Alberta, Canada
    3,631
    Taken off the CC website:
    "8. Iíve calibrated, but the car goes backwards with forward throttle.
    Make sure the green LED is showing when you give forward throttle. If it is, then just swap any two of the ESC to motor wires to reverse the rotation direction of the motor.
    If the ESC shows the red LED with forward throttle, you will need to reverse your throttle channel on your transmitter (via a micro switch, or within the programming of the radio) and recalibrate."
    Vantage/MMM/1515 Revo
    MMM/1518 Revo
    T-Maxx 3.3
    156
    Went home for lunch, swapped the wires and re calibrated and it's turning the right way, thanks
