    Tazewell Va. Were so small here in taz. that we only have 3 stop lights....and one is broke
    169
    center driveshaft install....HELP !!!!
    so i lost my directions.......i need help.....do i install tthe cups at the front and rear end and the shafts at the tranny, or the other way aroun....a pic would be supper helpful....thanks
    Maryland
    334
    Go to traxxas homepage click products, find your truck then select downloads then find the exploded view you need... this one shows the front center shaft http://traxxas.com/explodedviews/720...Qi-24GHz-radio
    This one shows the rear http://traxxas.com/explodedviews/720...Qi-24GHz-radio
    Hope this helps
    No Limit RC of Maryland
    Maryland
    334
    Hope this helps
    169
    i upgraded to the metal center shaft.....not in the exploded view.....
    Alma, Michigan
    12,290
    It probably really does not matter...
    I would put them together in such a way that it was the easiest to slide the bulkheads in and out.
    169
    got it back together.....finally... it works great so far.....no more pin popping out of the plastic joint, even on high traction surfaces like thick carpet.....now it just flips onto its lid!!!!! its alot easier to flip it back over than pulling the skids and rebuilding the driveshaft.....used the traxxas steel center shaft....now I just need the cvds at all the corners!!!
