Is a THS hard coat better than stock blue pipe.is it worth the money i mean for 50 bucks
It better make a noticeable differnce any body got any info
I have on on my Jato. It's better than the stock pipe and worth the money imo.
Jato 18TM, Revo 3.3, Nitro Stampede 3.3
Yeah, it gets great reviews and its worth the cash. This is Jato Tested and Board approved.
Next up would be the Buku Pipe, that is very cool, it gets great reviews. The Buku has a spring mounted cone that initially compresses the spring optimizing the return pulse for low rpms, the spring gradually decompresses and at the same time gradually optimized for higher rpm as the rpm climb. Essentially its a variable pipe providing improved performance in low, mid, and high rpms. This pipe is also Jato tested and Board approved, I would say the highest recommended.
This is the wild card. This pipe is Big Block Savage X Tested. Basher & High Speed Modified Engine approved. I run this on my Big Blocks and it obliterates all other pipes on the market. It's hand welded, made to order and not cheap, a lil more then double the THS. This is the ERCM 222T (I run the 221T on the Big Block .30's) this pipe drastically increases the strength of the return pulse to increase the "supercharger" effect of "Tuned" pipes. This increases the boost from the pipe in the entire power range, but still can be optimized by header lengt. The gains are astonishing, without question, and from every single person anybody asks who has one, the gains are more then you will expect, makes you go "wow".
This pipe has been run on a Jato and the owner was blown away by the power, however its not tested on this board (its a underground, race illegal pipe) I will soon order, test, and review the 222T on my Jato. Then post up here.
So you would say buku is better than ths????i have stock 3.3 with t-maxx air filter I really ant looking at
Dollar signs just more speed and power
But i hate to wast money on something that barly showes differnce.also here comes big question lol
Which buku is best for the traxxas 3.3 and how do i order them and from where
Thanks for info
I'm checking on internet and nobodys got buku pipes . There website says product unavalable
The buku pipe is probably a better than the ths but its also more tuning is involved. I really want the ercm pipe. I'll get it eventually. The THS is gonna be the best bang for the buck. You'll notice and hear the difference right away. Also the buku pipes for the Jato are getting hard to find.
THS pipe all the way!
