new to posting in general. i have tried this product and highly satisfied with results. no more glo plugs or glo fuel. simple to convert/change head/fuel line/fuel cap o ring/ fuel type/connecting rod. traxxas easy start will also work with this.use a fully charged battery will give good results starting as the engine now has higher compression. engine compression is ajustable by simply turning a allen head screw on the top of the head . they do recomend a starter drive system and battery operated drill. how ever i used a electric drill. do not ,i broke the one way bearing in only a few starts. this led me to try using the easy start and it worked. as for tuning there is a learning curve, even if you have years of nitro exp. instead of going leaner to go faster you go richer and adjust the compression/ also called timing. after under standing the tuning procedure i became happy with the torque and power of the motor. best results performance wise will be to use a bigger clutch bell with more teeth and smaller spur gear. how ever stock gearing works well. this engine now makes a lot of torque and taller gearing will produce harder accelleration and top speed. advantages are no glo plug cost/uses almost one half less fuel than glo fuel/almost twice the amount of run time per tank full/longer engine life as rpm is maximum of about 15,000 rpm. disadvantages are/ you will have to change gearing if you want to do wheelies/fuel cost is more,but you get almost twice the running time as compared to glo fuel per tank full.cost of conversion is $130.00 for one traxxas 3.3diesel head/one super duty connecting rod $40.00/4 quarts special type diesel fuel $51.80/about $25.00 shipping/total cost of$250.00 approx. note /the fuel is not regular diesel fuel you buy at the local gas station. last, i would only recomend this conversion to guys that have a strong under standing of engine tuning. to obtain this product google rc car diesel conversion/or traxxas revo3.3 diesel conversion/you tube traxxas revo3.3 diesel conversion
video.
