Hello, I would first like to introduce myself as I am new to this forum and also to the RC hobby. My name is Keith and I am from Ohio. I have recently acquired a 1/16 Revo (model 7107)... I have recently purchased the "needed" upgrades for my revo. These include: Traxxas steel CVD's, Traxxas aluminum pushrods and toelinks, RPM A-Arms front and rear, RPM axle carriers front and rear, front and rear aluminum chassis braces.
After researching a litttle and watching some youtube install videos about some of the upgraded parts i have purchased. I started with the rear end, dissasembling everything and have finished the rear end with the steel cvds, aluminum pushrods/toelinks, rpm axel carriers and rpm arms but run into a problem..
The problem I am having is when i put my stock wheels on the back, they are rubbing/hitting/touching the rpm axel carriers??? Did I do something wrong? Is this a common problem with the stock revo wheels? I put on some different white wheels i got from thetoyz.com to see if they rub and and they do NOT rub...?
Please fill me in with any input, advice or answers you guys may have!
Thanks in advance!
( I have not finished installing the parts on the front, but id assume they are going to do the same).. When I put on my aftermarket white wheels/tires that are a little deeper dish, the axle carriers do not hit anything? I think it could just be the stock wheels, but I believe I have seen the RPM axle carriers and stock wheels on other peoples mini revos? Correct me if im wrong or if that combination does not work?
