not sure, you changed the gear ratio in the trans correct, not sure how that will work out....hummmm.. lets see....
need tire size...OD...??
Diff ratio
4s = 40 mph
5s = 50 mph
6s = 60 mph
change the cell count, spur & pinion count, & tire size.
BrianG speed chart:
http://www.scriptasylum.com/rc_speed/top_speed.html
Copy / paste: Import this:
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.8333333333333333
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 21
Total Voltage: 22.20
Motor KV: 2200
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 3 : 1
Total Ratio: 15.65385 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Rollout: 1.18:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 54.76 mph (87.97 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
