Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 672
  1. #81
    Jul 2011
    143
    wait, are you saying that the pitch of the input gear did'nt match the rest of the internal gear? internal tranny gears are mod one or 24 pitch and i would assume that since RR made this input gear for revo that they should match? to my understanding that if your second gear has 38t and to mesh it right, you have to get the 18t input gear.
    I'm saying the tooth shape is different, as if RR and Traxxas use different pressure angles.
    After running in the tranny on a work bench, things improved some, but it is no where near as butter smooth as with all traxxas plastic gears.
  2. #82
    Long Beach, California
    6,727
    thanks dude
    my diffs are from E-REVOs and yes the tranny are lock on 2nd gear. i bought my MMM off EBAY chop shop, at that time it was $275 shipped. this thing is awesome to drive, handles good, wheelies on demand.
    heres a pic of 2nd gear lock-out
    Quote Originally Posted by rc driver dude View Post
    Awesome build! I have a 3.3 and was thinking about converting it, but was worried about the price. You did a great job customizing everything to fit.
    A few questions
    Are those the nitro diffs? Did you lock the transmission in one gear? Where did you get the esc and motor from and how much were they? Also last thing, how does it drive?
    Thanks
  3. #83
    6,727
    i find it more rigid than the plastic. when i pop whellies on the plastic chassis it twist and rock back and forth, this chassis is pretty solid i dont see any movement. you can do carbon fiber chassis except you cant mess around with it unless you really want to,(what i'm saying is that its too expensive to mess with it, lol). yes you can do carbon chassis + conversion (tekno)and be done with it.
    i have pretty much all the stuff that i needed to complete the build, all i did was transfer my MMM system to the assembled REVO chassis and oohh i did buy the electric motor mount $25 and summit suspension $12 + shipping.
    Quote Originally Posted by IvVaum View Post
    wow...is the chassis of the revo better than that plastic e-revo?...was thinking about that a carbon fiber chassis...and a conversion kit...and then transfer all the stuff on my e-revo over to the new chassis...what do u guys think?...i just want a stronger body than the plastic it has now...
    how much did the parts cost u?...just want to get an idea of how much this is going to set me back...
  4. #84
    447
    i'm debating whether i should buy the revo chassis and tekno conversion kit...or...if i should go with the kershaw body...what do u think?
  5. #85
    6,727
    well with KD you get what you paid for. i'm doing this for experimenting and trying something different so that i have something to tell, lol. so far its holding up pretty good
  6. #86
    447
    u know...if u want to try something different...and believe me...i'm seriously thinking of it...get a carbon fiber molding kit...make a mold of the e-revo body...per se something like this...
    http://youtu.be/VodfQcrXpxc
    and once u perfect it...u can churn out carbon fiber chassis left and right...perhaps much easier than milling out aluminum?...i dunno...but dang it...i really really want to try it...(just not enough time)
  7. #87
    Jul 2011
    143
    I have a Tenko kit. It's a clean installation and I really like the motor mount, but I don't like how far the battery sits. The battery tray is also quite shallow. The kit also places an aluminum monut high on the tranny case. A 150A ESC is not the lightest component in the world. so basically, I'm not happy with their weight distribution. On the new build I just finished on another truck, I used an SCTE battery tray. With minor modifications to the chassis and tray, it fits great. The battery is much further forward and it provides a place for the ESC. I will have pics of this build soon.
  8. #88
    6,727
    OK, got my truck running again gear at 14t/38t and still cant open the throttle wide without lifting my front end up in the air, even though that i move the battery forward. so i lower the pinion back to 13t and i can open the throttle all the way but its a bit scarry and i think its due to my tires balloning up bad, i need a street tires for this speed run LOL. its funny cause when i have my ERBE chassis before, i can open the throttle all the way and not have to worry about lifting the front end up in the air (sure the tires are balloning but still controllable) and thats with the same tires and the same lipo batts but the gearing is different i have 20t/40t the (same mod one by the way).
    previous set up
    present set-up
  9. #89
    6,727
    yey, finally my 4s lipo showed up in my front door, UPS drop it off . what a big difference with its thickness compare to my 2x 2s stack together, its much smaller and a tab bit shorter. here are some pictures,
  10. #90
    kansas
    7,895
    let me know how they work^ been looking (genace) for a set of 2/4s for my 5ive.....
  11. #91
    6,727
    i sure will. this is what i was going to buy but at that moment they're out of stock and i look at it again today and all of the sudden they have it in stock. i kinda like the hard case though but ohh well.
    http://www.hobbypartz.com/98p-40c-50...se-direct.html
  12. #92
    kansas
    7,895
    that what I was looking at...
    I am good either way, but I would rather not have a hard case...
  13. #93
    6,727
    they have the 5000mah and 5300mah soft case, but it looks like nobody have post a reviews about it yet. http://www.hobbypartz.com/gensace60c4s.html
  14. #94
    kansas
    7,895
    60c......
  15. #95
    6,727
    my last and final set-up i can't think of anything else to do with it, LOL.
    heres the video running for the first time on single 4s
    http://www.youtube.com/watch?v=IO3Yq...&feature=g-upl
  16. #96
    kansas
    7,895
    looking & sounding good...
    but where is the body, take'n a chance
  17. #97
    447
    quick question for u...can u push or roll your revo-e without it binding up or clicking or stuttering...
    i haven't powered mine up yet...but it doesn't roll smoothly when i push on it...the transmission seems to be binding and locking up...is this normal?...
    my erbe doesn't do this...i wonder if it's the metal gears that's in the tranny...well i know it's the metal gears in the tranny cos the noise is coming from the tranny not the spur gear...just wondering if this is normal...
  18. #98
    Jul 2011
    142
    It's not rolling smooth because of the magnets in the mamba motor.
  19. #99
    Jul 2011
    142
    Humayra hows your tranny holding up?Mine seems to be doing better.I lossened my slipper up and turned my braking power down seems to be ok.
  20. #100
    447
    Quote Originally Posted by slowrider998 View Post
    oh really?...so that is normal and not some sort of binding?...i'm surprise it does that...it's a brushless motor...aren't those things suppose to be smooth?...my velineon and ********* motor doesn't do that...that's weird.
  21. #101
    Jul 2011
    142
    yes it's normal.If you take the motor and spin the shaft you can feel the resistance.
  22. #102
    6,727
    its totally normal your motor have so much resistance that when you roll it, it stutter, specially that the motor is 4 pole, those magnet are super strong that you can hardly spin the shaft with your hand, i agree with slowrider998
  23. #103
    6,727
    its actually holding up pretty good man, yes i did the same loosened the slipper clutch too, i have the HD slipper clutch and once its warm up it just grab at any throttle i put it on. i change my 3 roundheaded screws thats holding the 2nd gear lockout to a flathead screws and flush it evenly with the aluminum clutch.
  24. #104
    4,840
    most if not all the brushless motors have some good resistance i know my hobbywing xerun does. i tried it today and checked that again and there was resistance there before i ran mine.
    DEU 8:18 ESV
  25. #105
    Jul 2011
    142
    Great glad to hear the trannny mods are holding up to brushless power.I went with 2 allen cap screws then threaded the plastic hole.Epoxied the cetrifical clutch open.
    Your build came out awesome man !!
    Ive done the same but used most of the techno kit.So thankyou for posting your build with pics!
    Cheers man
  26. #106
    6,727
    my wheelie bar came in the mail along with the wing, still waiting for my black blast wheels/phaltline tires<---its not preglued by the way, and extended rear a-arms. i'm also going to order a PL slipstream to complete it.
  27. #107
    447
    thanks for the confirmation guys...i appreciate all your responses...glad there's nothing wrong with my newly purchased car...still waiting for a receiver so that i can run it...may just pull the receiver from my merv to test out this thing...
  28. #108
    6,727
    your welcome IvVaum, you bought something thats worth every penny, for sure.
    i recieve some more part today, my hpi blast wheels and extended rear a-arms, installed it in no time and wow its about the same as my summit wheelbase now. take a look:
    with extended on
    with the stock on
    P2 rockers on with no issue rubbing with the axles
    and my blast wheels with the extended a-arms on top
    still waiting for the phaltline tires
    few more pix with my summit
  29. #109
    6,727
    well guys, today i shread my input gear for the second time and so i dig deep into my pocket and order this http://www.ebay.com/itm/RRP-8007-Ste...item4d04738c89. anyone have this on there revo trans and what are your thoughts? thanks.
  30. #110
    Apr 2009
    380
    Pick up some good gear grease for those. They're going to be very loud unless greased heavily.
    My concern with that is cracking the tranny casing or exploding your differentials. I'd personally use a plastic spur to help keep the breaking point cheap.
  31. #111
    6,727
    definately stay with plastic spur, i dont bash this truck, its more of a speed runner and i think the stock plastic gear inside develop so much heat and stress from going to fast that it shread into pieces.
  32. #112
    Jul 2011
    142
    I have one that i locked into second.Ive only run it a couple times easy seemed like a lot of stress on the slipper.
  33. #113
    6,727
    i have a traxxas HD slipper clutch on right now. i might just use the RR 2nd gear and the input top gear.
  34. #114
    Jul 2011
    142
    Seemed to have a bit moe snap with the lighter plastic gears.Alot less wheelie prone running the rr gears.Front wheels bite in better too.
  35. #115
    55
    I'm new to all of this and this may sound stupid. But why must you lock it into 2nd. I am ignorant plz help me not be.
  36. #116
    6,727
    first gear is too much torque to begin with and that you end up fixing it more than playing with it. locking it on 2nd gear tame it abit and more controllable.
  37. #117
    Jul 2011
    142
    Keep us posted on how the rr gear/plastic gear combo goes.Thanks
  38. #118
    6,727
    sure will, once i recieve it thru the mail, then install it and with plenty of test run
  39. #119
    6,727
    since i'm still waiting for my RR tranny gears and tires i decided to mock up my wheels and take couple of pictures.
  40. #120
    6,727
    i've been thinking about eliminating my on/off switch on my MMM ESC. guys got any tips on how to?
