Results 1 to 22 of 22
    Jul 2012
    Long Beach, CA
    17
    New ERBE owner with battery question
    Would 2s lipo battery packs be a healthy upgrade from what comes stock with the truck? And if so do I
    physically have to alter anything on the truck to accommodate the new battery packs power?
    Thanks!
    Andrew
    kansas
    7,862
    This is a good start..
    Just don't buy no name Ebay batts...
    MY BATTS:
    2S 9000 x 28C = 252,000 divide 1000 = 252 amps
    2S 8000 x 28C = 224,000 divide 1000 = 224 amps
    3S 5200 x 40C = 208,000 divide 1000 = 208 amps
    2S 4700 x 25C = 117,500 divide 1000 = 117.5 amps
    ^I run in my Summit.. ^ Requires proper gearing^
    ( mah x c rating / 1000 = amps)
    The more amps the better / minimun of 120 amps.
    The ESC will only draw the amount of amps it needs.
    Higher the mAh the longer the runtime.
    For brushless systems 8000 mAh about 45 min & a 5000 mAh about 30 min.
    Times are longer for brushed systems.
    Batts in series double the voltage:
    2x 2s 20c 5000mah = 4s 20c 5000mah
    Batts in parallel double the mah capacity:
    2x 2s 20c 5000mah = 2s 20c 10,000mah.
    A temp gun is kind of a must have.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    Besure to check sizing before you buy any batteries...
    In time some batteries will become discontinued...
    No particular order as to good, better, or best....
    2S
    With larger Lipo battery wires, you might need to - enlarge the exit hole on battery doors....
    or run wires out the vents..
    Direct Fit...........
    2s GensAce 5000 mAh 40c
    2s Gensace 5300mah 30c softcase packs
    2s HiCountryHobbies/Billowy Power 5200 mAh 50c
    2s Hyperion 5000 mAh 45C Soft
    2s RC DUDE Power 5000 mah 35c
    2S Sky Lipo 5000 mah 40C -- fit snugly
    2s SPC 5000 mah 25C hard case
    2s SPC 5200 mAh 40C
    2s SPC 5400 mAh 50C hard case
    2s SPC 6000 mAh 30C hard case
    2s SPC 8200 mAh 30c
    2s SMC 5400 mAh 50c
    2s SMC 6000 mAh 28c
    2s SMC 8000 mAh 28C Soft Case Lipo
    2s SMC 9000 mAh 28C Soft Case Lipo
    2s SMC 9200 mAh 50C
    2s Team Orion carbon 7000 35c
    2s Thunder Power 45-90c 5000mah
    2s Over Sea's Co. 6000mah 25-50c
    2s Traxxas 5800 mAh 25c
    2s Traxxas 7600 mAh 25c
    Mod's.............remove retainers & back out or trim screws if they extend into battery compartment
    2s SPC 8200mAh/40C
    2s Over Sea's Co. 30c 5000 mAh soft - Extend Batt Door Out
    2s Over Sea's Co. 5200 mAh 5.2 Hard Case - Trim Batt Door For Wires
    2s Over Sea's Co. 5000 mAh 5.0 Hard Case - Trim Batt Door For Wires
    2s Over Sea's Co. 5000 mAh 30C hardcase
    Jul 2012
    Long Beach, CA
    17
    Thanks for a quick response! That guide is really going to help. Now do I need to change any of the gears to accommodate the
    2s lipo batteries?
    Thanks,
    Andrew
    kansas
    7,862
    Start with the supplied 54 spur & 18 pinion.
    I run 2/2s 9000 mAh 21/54 at low 50 mph, all temps are good.
    Nov 2011
    Western Kentucky
    792
    The lipos will put a smile on your face...just take it easy or you will have axle & differential failure
    ERBE,Losi 8ight,Slash 4X4
    Jul 2012
    Long Beach, CA
    17
    Okay great I found that part, now this is how much of a newb I am.... How do I got about swapping out the old gear with the
    54/18?
    Thanks,
    Andrew
    kansas
    7,862
    Jul 2012
    Long Beach, CA
    17
    Thanks for the link man! I think I can manage that gear swap out
    Andrew
    Jul 2012
    Long Beach, CA
    17
    Just ordered some of the Traxxas 2S 2-Cell 7600mAh batteries off of Amazon. Should have them sometime next week. I also ordered up a dual charging adapter for the 2S lipo's, so hopefully that'll get me using my revo faster. I didn't realize how long it takes for the batteries to charge. Is it normal for a 7 cell 8.4v 3000 mAh battery to take over an hour to charge?
    May 2010
    Silver Spring, MD
    216
    ^^ You're gonna love the traxxas lipos! I have the same ones you just ordered and a pair of 5000mah 3s. I also bought the dual charging adapter for both sets and they normally take between an hour to a hour and a half to charge.
    Jul 2012
    Long Beach, CA
    17
    Thanks for the info! What are the run time differences between the 3S 5000 mAh and the 2S 7600 mAh?
    kansas
    7,862
    higher the mAh the longer the run time
    the more cell (higher voltage) the more power & speed
    C Rate is discharge (punch)
    5000 little over 30 min
    8000 well over 45 min
    but you are comparing a 5000 3s to a 7600 2s.
    You can't get an 8000 3s to fit the Revo with out major mod...
    Start with a good set of 2s batts then decied if you need a set of 3s.
    like 5000 mAh 40C........ 200 amps
    104
    i would not run the stock batteries unless you make sure the low-voltage setting is correct
    May 2010
    Silver Spring, MD
    216
    Yeah like 87 GN said its kinda hard to compare the run times between the two sets especially since I bash more with the 2s and the 3s is mainly for speed runs. I get about 30-40 min with the 5000 and I get anywhere between 45-60 min with the 7600's. It really depends on how you drive the truck.
    Jul 2012
    Long Beach, CA
    17
    I guess it would be difficult to tell the differences between the two for run times. I'm looking forward to the power increase and
    the extra run time from the 7600's though.
    Jul 2012
    Long Beach, CA
    17
    I just got my 7600's in today. Everything seemed to be going good, but when I went to set the amps for the battery my
    charger, the EZ-Peak Plus only goes up to 6 amps. Does this mean I can't fully charge my 7600 mAh batteries I just got?
    kansas
    7,862
    no it just means it will take longer to charge.....you still charge to 4.20v (full)
    Jul 2012
    Long Beach, CA
    17
    Thanks for the reply. Man the 2S's last so much longer than the stock batteries! They seem to be a bit faster too, however I'm
    Already getting the want for more power. Luckily I just found out that there's a rc shop about five minutes from me that
    specializes in traxxas rc cars and they have a big selecetion on pretty much anything I need to maintain/upgrade my truck with. I'm gonna play around with the 2S's for another week or so, then I'll probabaly take the plung to two 3S batteries. I'm thinking
    I'll swap out my stock pinion to a 18t one to work with the 54t gear that I just installed. Any thoughts On how well that setup
    Would work?
    Virginia
    826
    The stock pinion is 18T. What do you have on their now?
    ERBE, Summit, Thunder Tiger MT4
    Jul 2012
    Long Beach, CA
    17
    Oh I thought it was 16 for some reason. If its stock then its the 18t right now. Since I put the 54t gear in should I change the pinion to accommodate the smaller 54t? And if so, to what size?
    kansas
    7,862
    before you get a set of 2/3s try ............... 21/54 on 2/2s is low 50 mph
    not heat issues......
    Jul 2012
    Long Beach, CA
    17
    21 you say? Excellent I will try that out and let you guys know how it goes!
