Results 1 to 3 of 3
    Maryland
    333
    Velineon 380 with VXL 3s??
    My sons 4 day old VXL 3m quit working last night so I called Traxxas and they are going to replace it I have a spare VXL 3s and I wanted to know if I can use that to power the Velineon 380 or will it burn the motor up? Also will his 1/16 batteries be enough to power the VXL 3s?
    No Limit RC of Maryland
    2,016
    it will power the motor easily without problems. The only issue will be the wire bullets, The vxl 3m system uses thinner wires/bullet connectors than the vxl 3s system. so you would need a wire adapter to connect the motor and the speed controller.
    MAN, Use Common Sense
    Funky Gecko, SumVee HDE
    Maryland
    333
    Just checked and the bullet connectors are the same size
