+ Reply to Thread
    90
    Low gearing on 3s lipo cause temps too go high ?
    17 pin 86 spur gear--temps gets up too 171 after 15 mins off bashing with few speed runs in between-
    Rotterdam, Netherlands
    6,258
    171 is quite high, but still not too high.
    Nobody is born with experience.
    Jul 2010
    Beautiful SoCal
    869
    Thats high for that kind of gearing...I run 23/76 and get 130F on 2s.
    Jesus, Lights, RC, Minecraft, LoL
    6,343
    Tell us a little bit more about your truck. What ESC/ Motor are you running? I've run 19/83 on 3S and my temps got up to 160* but that was mid summer @ 100*^. You have a few options to cool the temp down some. Get you a heatsink or alloy tranny case. The case helps a bunch.
    You can also gear down a tooth and that will help out. 16/86 should be fine on 3S.
    Rudeness is the weak man's imitation of strength.
    1,836
    That 3S will run temps that high for the most part. If the truck seems to be 'redlining' a lot of the time, you may want to actually try gearing up a bit to stretch the power band some, add a little more top end speed and still be able to keep your temps around 170.
    Jul 2011
    Benzonia, Michigan USA
    135
    check for binding
    Started XL-5 now VXL-XL! and spare parts XL-5
