Results 1 to 34 of 34
    156
    3.3 to brushless, what do I need?
    So I've been messing with a revo 3.3 that I've decided to just turn to brushless instead of messing with rebuilding or buying a new 3.3, so what do I need? I was thinking of the velineon, will it work??
    This will be my first electric, what should I not do?
    I am here: http://tapatalk.com/map.php?4gsidv
    Long Beach, California
    6,880
    a single velineon is too small to begin with for the truck, i would be worry on the temp. your better off getting the right motor for it (1/8 scale). are you keeping the aluminum chassis? are buying a conversion kit of it? tekno makes a electric conversion kit ( a bit pricey but, you get what you paid for, its quality) if you look around, you might find a good deal for a BL motor/ ESC for less than $200. to give you an example, check this out, http://www.rcecho.com/HOBBYWING-XERU...mbo-ME222.html
    | Rally GT8 Powered By CC |_________________ |
    kansas
    7,949
    156
    this link doesnt work
    156
    should get my mamba monster saturday
    156
    Looks like I finally got In all my parts, hope to have running in the next few days
    156
    Well I thought I had all my parts, but eBay seller didn't put my Savox servo in the package
    kansas
    7,949
    DoH bummer.. have any more pic yet.
    156
    So I I've been working on it, wired in a Castle creations 10 Amp external BEC
    Ran into a problem, the cables on the motor to ESC, are to short for the tekno esc to be used, so I can either relocate the mount or get longer cables
    156
    Locked in second gear and installed center diff with stock 100k oil
    6,880
    what are those other gears you have inside half trans case?
    156
    They are the ones that were already in it, I think the metal gears are from the reverse
    6,880
    aahh, so you dont need those gears anymore, since you have locked 2nd gear. great build by the way, mine is not as close to yours but i'm getting there.
    156
    im also putting some lights, will be using the revo 3.3 for now, i bought some lights from hobbypartz.com i think they were 7$
    i put the white in the front and the red in the back,
    where should i put the blue blinking lights??
    156
    ok link is fixed
    156
    So the cables on the motor are not long enough to reach the esc on top of the tranny where the tekno mount Is meant to hold them,
    So I pulled the 2 screws that hold the shocks to The chassis and drilled 2 holes in the tekno esc plate mount and mounted over the shocks, I've used some industrial strength Velcro and that's where I'll put my esc for now unless a problem comes up
    6,880
    this conversion kit was tested with the green castle motor with the longer wires, and the motor you have now were meant for ERBE/EMBE versions only. i've seen ppl mount them right were you have it now with no problem, thats the location were i'm going to mount mine also.
    156
    so i have ran into a little dilemma
    when i press the throttle on the transmitter, all wheels are turning backwards, making the car go in reverse, looking at the cables plugged into the ESC left to right is white red black
    are these backwards?
    156
    Do I have them wrong?
    6,880
    try switching the black to white and white to black.
    heres mine,
    156
    By your pic, looks like its wired the same way as I have mine
    6,880
    i was gonna say the same. maybe you need to recalibrate your RX/TX to ESC?
    Quote Originally Posted by Inflic501 View Post
    156
    I re calibrated this morning and same thing...
    Jul 2005
    405
    Please have no doubt that I will stand by the ESC and motor I sold you...but by that video it does appear to be spinning counterclockwise...ie backwards. Two things....have you kept the stock battery lead wiring from ESC to batteries and also any chance the battery leads are reversed?
    ERBE, Slash
    RIP Jato and Revo w/ RB TM323
    Mar 2005
    Des Moines
    2,559
    Either swap any two motor wires (easiest method) or use the Castle Link software (to retain your aesthetic wiring) to reverse the motor direction. Either way works and both are easy to do.
    NEVER, EVER swap the battery leads around! That will blow the ESC for sure.
    http://scriptasylum.com/rc_speed/
    156
    I made adapters for the battery's, traxxas to bullet connections
    Jul 2005
    405
    Thanks Brian...yeah, definately did not mean to suggest swaping th battery leads on purpose.
    Inflic...any chance we can get a pic of the battery to ESC connections?
    ERBE, Slash
    156
    I dont have one on my phone right now, I'll take one later today
    156
    Went home for lunch, swapped the wires and re calibrated and it's turning the right way, thanks
    Received my Savox steering servo in the mail today, so I might be able to get my first run later today
    156
    All done!
    Ran about 20 minutes, just around the parking lot and yard everything held up well, did notice to much power going to the front wheels, they will bubble up before the rear wheels, any tips??
    What's missing?? The pads!! Wore them all out.. Whats a better pad than just the traxxas stock???
    kansas
    7,949
    156
    They weren't allum
    RC Turnbuckle Jr. ajb1205's Avatar
    Apr 2007
    Alberta, Canada
    3,631
    Install 500k oil in the center diff...or remove it all together. You have to run your slipper darn near locked down or you will burn up slippers constantly. I installed a RRP Gen 3 slipper on my E-Revo and it was worth every penny.
    Vantage/MMM/1515 Revo
    MMM/1518 Revo
    T-Maxx 3.3
