Results 1 to 12 of 12
    South of St Louis
    5,987
    MOTOR MOUNTS-- King Headz vs. STRC vs. GH
    Bought a new Sl4sh roller off fleabay and would like to upgrade the motor mount.
    I know the King Headz is popular here. How about the STRC or GH? Any opinions on these or a different brand?? I plan to squeeze in a 1/8 castle motor.
    Lilydale, Victoria, Australia
    2,845
    If they have a larger bearing any of them will do the job
    Cheers
    Slash Platinum
    Xerun 150 / Tenshock SC401 3500kv
    782
    i have had both of them...if you dont help the bearing with extra lube......they all suck
    i actually have been using losi bearings
    waiting for Traxxas to make something new!
    South of St Louis
    5,987
    This is from the STRC website but doesn't state bearing size.
    South of St Louis
    5,987
    The GH piece uses a 10x19x5mm bearing.
    Feb 2010
    El Sobrante, Ca
    7,795
    I have used the King Headz and STRC mounts. Like restless says, you need to add lubricant to the bearing to help it live longer.
    South of St Louis
    5,987
    How often do you lubricate them?
    South of St Louis
    5,987
    Here's another from FLM, made in the USA:
    Rotterdam, Netherlands
    7,313
    I have read about fitment issues of the FLM. The STRC uses the same bearing size as stock and the holes might let unwanted material through them. King Headz seems to be the most popular and that has a good reason IMO.
    QUEBEC CANADA
    105
    i have the gh one... it was in stock and cheaper than the kh at my lhs. so far so good. direct fit, bearing is strong. i can recommend it.
    Long Island N.Y.
    70
    What type of lube do you use?
    Feb 2010
    El Sobrante, Ca
    7,795
    I use automotive grease or shock oil. It helps prolong the life of my bearings. Been doing it for a long time. I still have some original bearings on the slash I bought in January 2010!!!
