    Jul 2011
    Ontario, Canada
    68
    Question New Sky Lipos need charging?
    I just received 3 new 2s 40c 5000mah sky lipos with a skycharger. now, i can't test run them since i'm in the process of getting new parts and a new esc/motor for my crippled slash. But, can I balance charge them at all if brand new? I tried one but it took like 6 seconds and that was it, idk what i did wrong if anything, I asumme they're fully charged? I set the correct setting at 5.0A as well.
    Little guidance? First time LiPo user, I don't wanna blow anything up.
    Nov 2011
    Austin, Texas
    970
    I have never recieved a fully charged sky. What was the voltage of each cell?
    Jul 2011
    Ontario, Canada
    68
    i volt tested the plug, it was 7.65 for all of them. i'm not sure what each cell might be, how do i figure it out?
    Update: Tested the voltmeter to the balancing cable and got a reading of 3.82? is that normal?
    Sep 2009
    Victoria B.C Canada
    5,144
    A fully charged 2s is 8.40 v
    4.20 v per cell.check the settings on your charger.
    Sent using magic and trickery
    Ok it was Tapatalk
    Mountains cant stop me
    they have tried
    Jul 2011
    Ontario, Canada
    68
    8.4v for 7.4v 2s? sry if thats a noob question lol.
    Jun 2009
    W Monroe, Louisiana
    1,993
    Quote Originally Posted by InceptorOne View Post
    yep. 4.2+4.2=8.4v and 3.7+3.7=7.4v for a 2s
    4.2v per cell is charged voltage.
    3.85v per cell is storage voltage.
    3.7v per cell is the nominal voltage which the battery will plateau at (on a bar graph) when under load.
    3.5v-3.2v per cell is the typically accepted Low Voltage Cut off.
    3.0v Never run below this as it will harm the lipo.
    Never leaved fully charged more than a day or two but place at a storage voltage of 3.85v per cell. If storing for a period of time then check each month.
    South of St Louis
    5,986
    My SPC lipo directions said to charge before first use.
    15,697
    For technical support of non-Traxxas batteries or chargers, please consult their respective manuacturers.
    Alt-248 on the number pad =
