Well I converted my tmaxx to a emaxx but I keep blowing out the rear Diffs. Can you use all the parts out of a new emaxx diff and just put it in the old housing
Can't say for sure abut internals fitting in the old case, but the new (complete) emaxx diff will fit right in the place of the old one.
Do ou think they would be a lot stronger
The new 4 screw style diff will work great the drive output shafts seem a tiny bit shorter wich makes the grub screws hard to get it but I have not stripped a pinion since I upgraded. I have only broke the cup screws since
what parts are you swapping over? It seems strange to just swap the complete internals (including ring gear,diff carrier,spider gears,I-bar) over to the old housing.
Motorcycle/Quad,Think sand vehicle, piggy backs
I just have 2 extra diff housings that are off a 2.5 tmaxx. It seems like everytime I play with it it would snap drive lines in the first 5min. Then I put MIPS front and rear and now it kills diffs
Is that the old 2screw diff housings, The 4screw version give less flex.
I bought some new diffs from a new tmaxx with the 4 black hex screws,I have noticed there is the 4 steel screw housings too.
Then i bought the I-bar and diff carrier and going to swap them over tonight/tomorrow with some lovely 500K lube.
I don't know if the different 4screw versions are the same but the black screws seem to have quite thick material.
There is a difference in the internals = pitch and mesh of gets in the 2.5 & 3.3 t-Maxx there are also differences between the brushed and brushless version with the 3908 diffs being the strongest of all... If you want to thorough about it you can shim all the play out if the diff. If your ... you may want to upgrade your pinion bearing... But by any means, if you are creating enough power to break the diffs you should probably UPGRADE them. Especially since they are a pain to get to.
Last edited by cooleocool; 06-14-2012 at 06:20 PM. Reason: Removed starred out word.
EMBE BANDIT VXL SASSY CLOD RC10L RC18MT
I was on eBay looking at parts an found some new tmaxx 3.3 differntials. Are they the same or should I look for Differentials that came out of a emaxx
Get the ones from the 4910 I have bought 3 from this person for my 3906 and they hold up great
http://item.mobileweb.ebay.com/viewitem?itemId=120927782378&index=0&nav=SEARCH&ni d=90991901129
No but I'm using lipo
With brushed power you'll be fine with the 3.3. Funny how much cheaper the T Maxx diffs are vs the E Maxx. Sorry, forgot you said it was a T Maxx![]()
Well I guess I'll find out lol I bought my tacon 2150 kv motor and hobby wing 150 easyrun last night
You'll love it! I have the Hobbywing SC8 ESC and it's one of the best I've used. Did you get the EZRun version 2?
Also found out that the 3.3 diffs are Revo spec and I don't know if the 4910's are. The difference should be the 3.3 is sealed and adjustable with different weight diff oil. If the 4910 diffs aren't sealed you can still use thick silicone grease to make it a pos-i-trac but the thinner oils won't stay in without seals. Heck, even with seals the oil lube finds it way out.
Yea I put 5k lube in the cup it works well and yes v2 on the ezrun
I blow diffs in my Erevo all the time...I am getting a bit fed up of having to open the diffs every 3 to 4 runs. I came across this thread about shimming diffs, it may be useful to you guys. I am waiting for my new diff gears to come and will try this. A tighter gear mesh will = longer life of the diff. Brushless power...you got to love it.
http://traxxas.com/forums/showthread...ff-Shim-Mod&s=
I'm a Rock n Rolla !
LST2 that's what I'm going to end up doing
I just put the brushless insides in mine, New carrier and I-bar. With some super thick 500K lube only done the rear, going for 300K for front.
Shimming diffs is a big +++. My new 3903 diffs didn't need shimming. They were tight but I can't say the same for my old 3906 diffs. I bought four screw diff housings, shimmed and o-ring sealed the old diffs but the power was too much and I blew a rear. Replaced it with the newer style diff and it's holding up great.
trax de max, if you find the truck pushes in a corner try switching the oil weights. 500k in front and 300k in the rear should help pull the truck around the turn much better. You'll notice the difference more if you get it on a track vs bashing around.
LD I have a 2150 toro motor with a toro esc I normally run 4's it was a tmaxx but I'm converting it to a 3908 emaxx
I believe it's a toro 8 not really sure I bought it as a combo. I have a toro combo in my slash and I love these combos. Great power
This post has been edited because of language abuse violation(s). If you see a starred out word in your post, the word has been blocked by the language filter. The language filter was put in place to block words that Traxxas deemed inappropriate for use on their forums. Please remove these words from your post in the future, or warning points will likely be issued.
Mines just off roading, not much mud lately as it's very dry where i am.
I've been eyeing that Toro SC120 for my SCT. I found the combo for $99.90 and that's a deal. The thing is my truck doesn't really need it, but I want it.....you know how that is.
Dry here too, trax de max. But I have a garden hose and dirt in the backyard![]()
I have the toro short course motor and esc the 4000 kv and it works great. I like how you get a programming card. On a 3 cell it's crazy you will need a wheelie bar
Have you tried it on 2s? What's it installed in?
It works good on 2s it's in a slash 4x4 no wheelies on 2 s but works well at the track. Running 2s geared at 11/54 it get about 130 in temp also
Just saw a review on it and it looks nice. Looks like a SC8 HobbyWing ESC and the specs look the same. They were saying the motors front bearing is bigger than the TenShock 401 which is a very nice motor.
Is it smooth with little or no cog?
Go on tower hobbies or amazon and get a good deal on the motor i buy lots of cheap parts there
T-MAXX 3.3
Only really coggs right now but I have it at a 18/54 trying to get some top speed runs. But will the 11t it's pretty smooth
