Results 1 to 31 of 31
    Nov 2011
    Planet Vegeta
    651
    is your slipper safe?
    i ran my slash in gravel. i heard noise from the tranny area. i opened the tranny. tranny is good. i run the mesh. there is noise. the spur is inclined. and it wouldn't come uninclined. i opened the slipper, pads are good. the disk edge ( center ) is bent. how did that happen? the pressure is good, not too tight. so next time you hear noise, check your slipper. again how could that happen?
    All I need now is to set a new lap record.
    Nov 2011
    Planet Vegeta
    651
    im getting a new slipper soon
    Nov 2011
    North Central OH
    1,048
    Are you saying the slipper friction ring was warped??
    You could have lodged a small stone in there somehow, bottom of gear cover has a notch cut out just above the output shaft, good place for rocks to enter.
    I have taped over this hole and use a small bead of silicone to seal the dust cover onto the trans
    Nov 2011
    Planet Vegeta
    651
    im getting a cover from RPM to completely cover the disk and spur from trash aka rocks
    573
    I started to go through spur gears till I got the RPM gear cover. Haven't had a problem since!! It pays for its self saving spur gears!
    Central KS
    1,071
    Funny thing but I bash on dirt and gravel all the time with no gear cover without a problem. My slash is now 32p but my Rusty and Pede are still normal 48p and no gear cover. Maybe I'm just lucky.
    What broke, uh, needs upgrading now?
    Greenwood Bashplex
    12,919
    You can get larger debris jamming between the gears, and break a motor shaft, but I have been bashing naked (no gear cover) for years with no problems.
    The only time I ever distorted that ring was cranking down too hard on the slipper nut. Have a pic of it?
    Sit down, buckle up, hold on, pay me...
    Nov 2011
    Planet Vegeta
    651
    i have some pics, but its not the angle i want it still. but im taking good pics
    Greenwood Bashplex
    12,919
    cool, it can get distorted when you crank the spring all the way down, before backing the slipper nut back off. A little too much torque and it can get messed up.
    Nov 2011
    Planet Vegeta
    651
    the disk is most likely cannot be bent back since its one of those small round edges in the middle
    Nov 2011
    Planet Vegeta
    651
    Quote Originally Posted by f687s View Post
    the whole disk should bend, not a little edge, rag6
    Greenwood Bashplex
    12,919
    I'm gonna need to see it. I am having a hard time visualizing it.
    How about a rock getting jammed in the clutch shoe/slipper ring area? Maybe as it spun, the edge was compromised by the rock?
    Nov 2011
    Planet Vegeta
    651
    let me describe it for now, the 8 little round shaped pegs in the center of the disk, on of those pegs, it is a bit bent up, im still trying to put pics
    77
    The "slipper pegs"?
    No, they should not be "bent" at all.
    Nov 2011
    Planet Vegeta
    651
    but it is, it sticks up and it somehow inclines the spur, making a noise when the spur and pinion move by the motor or wheels turing
    77
    Then you need to replace the pegs.
    Nov 2011
    Planet Vegeta
    651
    the little peg thingies in the disk's center, the flat silver disk
    Greenwood Bashplex
    12,919
    Pic posting...
    Now I can picture it in my head. Those little "guides?" would be really hard to bend without something jamming in there. Have no other ideas why it would happen.
    77
    Whatever you want to call them, if there are more than one and one of them is visibly screwed up - replace them.
    Nov 2011
    Planet Vegeta
    651
    im replacing it hopfully today
    South of St Louis
    5,986
    Sounds like the slipper tried to twist on the shaft. I've never had that happen... maybe it got overheated from being a little too loose... or too tight.
    If it got loose enough to pop out of position it might have gotten bent from all the torque generated from the motor. There is A LOT of energy in the VXL driveline.
    Nov 2011
    Planet Vegeta
    651
    only one side of the disk center pegs are bent, too bad my cam is not that high resoulution. and the shaft is scratch less
    St. Louis, MO
    655
    Once you get a new backing plate, don't put the cover back on. Even if you cover up the holes, stuff still magically gets in there.
    With the cover on once something is in there it just keeps bumping around doing damage. With it off, debris just bounces away.
    VXL Slash 2WD, VXL Stampede 2WD, and E-Maxx 3905
    Nov 2011
    Planet Vegeta
    651
    but does the proline or RPM cover protect it
    Greenwood Bashplex
    12,919
    is this whats bent?
    Nov 2011
    Planet Vegeta
    651
    yep rag6 and part of the disk is bent up and then straight
    Nov 2011
    Planet Vegeta
    651
    is this whats bent?
    and those pegs, 5 of then are bent up
    Greenwood Bashplex
    12,919
    no clue on how it would happen. Strange...
    Nov 2011
    Planet Vegeta
    651
    actulaly i recall that the first time i cleaned out the slipper, it had a rock, the spur was slightly inclined, but forcing it vertically and meshing it right, it didnt happen to be sound until now
    Nov 2011
    Planet Vegeta
    651
    i looked up some slippers, but none are for the slash, or any 272 tranny rcs
    Nov 2011
    Planet Vegeta
    651
    i finally got the slipper and the RPM cover
