Truckmonster sent me a package
This is what was in it. Work is stupid busy right now so it may be a few days before I get to them.
Ring gears
Spider gears can you tell the difference..lol
Sent from my iPhone using My fingers
Ring gears
Mountains cant stop me
they have tried
ya one is missing a tooth lol . black an silver
is the steel itself jet black or is it a coating over the gears
an how much are these things i need more dust colectors(not saying these parts are bad its that i got the aluminum in january and still havent installed them)
Oooooh Ahhhhh !! Me Like![]()
The Kid
Very cool.
So they are finally for sale. Do you have the aluminum diff cups. If so how does they fit together? Any shimming needed? Looking forward to updates.
proj 002: The Funky Gecko
Man, Use Common Sense!!
They are not for sale yet.. Just testing
Yes I have the aluminum diff cups.
If these work well ,haven't run them or installed them yet. Hopefully get time on the weekend,this pesky job thing keeps getting in the way....lol. There is talk of whether the pinion and other output gears will be needed.i haven't managed to break any of those ( other than the famous #5678 issue) when I first got mine 3 years ago or so. Many .....many miles on mine.I have worn more stuff out than broken things.this truck is amazingly durable.
they have tried
Hey Jam any update. If you need time off for RC stuff you can always take a month off for maternity leave. I think most of our trucks would financially qualify as a baby anyway.
Got a short climb in today.Going out again tomorrow got some video editing now. So far worked perfect. Once my tqi returns to me rx8 time,see if it likes that ... Lol it broke a single tooth off of one spider before the hardened ones went in.it kept driving just the rear would not unlock so to speak
Sent using magic and trickery
Ok it was Tapatalk
they have tried
a small vid of today worked great
they have tried
Tekin is back in,so this weekend we shall see how it feels about that.
WARNING. ---Brushless power in a summit set up for crawl/iming may cause serious lapses in judgment-----
Don't worry I have it under control....
5 minutes later here hold my(Beverage of choice) and watch this ....lol
Ok it was Tapatalk
they have tried
Update for those who would like to know.
the gears are out of steel, not coated but professionally hardened by
a German company. The black color is from the salt based hardening
process
- the special hardening method is the only way to harden the small gears
without making them too hard, normal hardening will cause them breaking
like glass
- the gears are not turned or molded, the are milled tooth by tooth, the
small ones need a longer manufacturing time than the big ones (ring
gear)
- I think that this hardened steel gears make only sense in non flexing
cups like the AL7075 ones
Ok it was Tapatalk
they have tried
Great stuff but the stock traxxas diff can hold up to slow rock climbing, hills and the avarage. What the masses would like is more testing such as;
1 - how does it hold up in 2nd gear bashing around and climbing.
2 - how does it hold up to extra big tires with high torque servo in a high traction area ( where mine failed)
3 - How does it do in a high speed test run when one forgets to unlock the diffs.
4 - How does it handles hard acceleration from a stand still with a brushless system.
No these are not the ways the summit was intended to be driven but we are talking about reality.
Has they mentioned a price range? I am waiting to purchase the gears and the diff at the same time.
Thanks greatly for your efforts.
Mine ate,yes ate diffs at a alarming rate
With the stock system. I do run it in hard conditions and had big tires.
Tekin is back in may throw the crushers on again and give it a blast.
I went this far because I want it reliable.
Waiting for parts and rebuilding the diffs
Is not as much fun as running the truck
Changing axles and shafts on the trail is
Quick,easy and cheap.matter of minutes im back running
Going out today to give it some testing/Abuse
Prices will be on his site shortly
Ok it was Tapatalk
they have tried
Pre run pic(Happy Canada day eh)
Ok it was Tapatalk
they have tried
Run cut short by breakage.had pinion
Loosen off twice fixed that then this i couldn't repair on the trail.... Lol
Tekin+ not taped rock crushers =
http://img.tapatalk.com/184424eb-ff8f-0cdb.jpg
Ok it was Tapatalk
they have tried
I just noticed that the gears are now showing up on their sit with more info, but are still not available.
Small set for 2 cups 79,00 EUR
- 2 x ring gears
- 4 x spider gears
Large set for 2 cups 119.00 EUR
- 2 x ring gears
- 4 x spider gears
- 6 x output gears
Summit TQi w/ Dewalt 14.4v, MERV
119 that almost 150 us/cad
Well I ran them with the tekin and the dewalt.i should say captain Idiot ran them(idiot driver on purpose) putting some video together
Rock crushers and tekin not the best combo.diffs fine.... Some other parts maybe not so much....
Ok it was Tapatalk
they have tried
so now with the diff bomb proof it will be the axles that are the problem for some people lol
got a question the kit the comes with the 6 output shafts are they just for the diff or is the two of them the pinion?
Pinion and ring gear two out drives and spider gears
Ok it was Tapatalk
they have tried
heres a small vid of some of the stuff i did
they have tried
I assume ring, pinion, and spiders would work in E revo brushless?
They should work fine the only real difference is the locker output is longer other than that they are the same parts I believe
Sent using lipo power
they have tried
I read a post somewhere recently but can't find it again. Someone was heat treating all inner differential parts by heating till red and dropping in oil then reheating and quenching in water. This post claimed that stock parts would shatter or snap under moderate pressure but that treated parts were noted to bend instead of break and that much heavier pressure was needed to bend them. What do you think?
just poppin it up for updates and experiences
I posted in the other thread.the hardened parts will take custom fitting
To get them to work.
they have tried
