Results 1 to 25 of 25
    woodstock .on.canada
    1,426
    well if it didnt quit
    xl-5 no lvd -trencher premounts-stock battery pack
    well guys the +wire on the titan 12t fell off about a couple of weeks ago and friday i soldered its up btw one of the poopyist solder jobs i have done. and saturday it died on me
    so it ran good for almost 3 stock packs and prior to it quiting it didnt want to go into revers but worked fine in forwords for about 2 mins i slowed to a stop to go into revers and nothing then tried forwards and again nothing
    so the hitachi 14.4v motor(550 sized) that i have wanted to try
    (visual specs)
    -same size as the titan 12t give or take 2-3mm on the lenght
    -same bolt pattern (direct bolt up)
    -the megnetic feild seems to be 2-3 time stronger
    -down side is the motor shaft is rilly short there for having to mount the pinion on backwards
    hooked it to the speed control by raping the wires around the esc connectors and put on a 19t pinion(19/90). that pinion contacted the spur by less than 1/3. so off i went and at the end of the half run the spur was still going good
    first in pression
    on a half dead battery pack it would wheelie from a stand still. and seemed to do half of the top speed from when the titan 12t motor was in(16/90). other than that the motor got luke warm. and when i was running it . it sounded like the comunicator gave off a diffrent sound . it might be becuase of no capacitors on the can itself
    on a fully charged battery it didnt seem eny diffrent power wise sept i could whellie going at about a couple mph. defenently has about half the speed compaired to what i had on previously . and at the end of the run the motor was a tenny bit hot
    so tomorow what im going to do is hook up the motor properly by soldering the motor wires to it. and make a flat spot on the rotter for the pinion. and after that i will try a gearing of 24/90 and see what it does for it
    and i know the motor is getting about half the voltage it should be getting
    Sep 2010
    middle o nowhere Ill-inois
    728
    I'm guessing that motor would be awesome in a rock crawler or scaler. As long as you have fun with it till you can get your pede back where you want it
    Pede 4x4, Pede VXL, Rustler VXL, LNC, Wheely King
    10,186
    If you want, you could get the 32p gears conversion. This would let you flip that pinion around to get more contact with the short motor shaft.
    LETS GO PENS!!!!
    1,426
    hay guys installed the motor monday in electrical class and it did a smidg better soldered up to the esc preformance wise
    i couldent get the 24t pinion to fit with the 90t spur but still i say this motor geared at 19/90 is about half the speed of what i had previously but run time lasted in around 30min with a stock pack that takes a charge of 2654mah but note i was driving it inside so i couldent rilly hammer it 1 becuase of the waxed floors 2 i didnt find a hole lot out side
    other than that i would recomend this motor if you have a dead hitachi drill laying around and are a week away from a new motor but on the other side i would recomend this motor to eny crawler that run's 1/10 brushed
    1,426
    hey guy tested the speed last week on the hitachi 14.4v motor
    with 2.8"trencher tires geared 19/90 i got a top speed of 14.6mph at peak and 13-13.8mph throught out the almost dead nimh pack i have
    so far no failures but the motor gets just as hot as the 12t geared 16/90
    1,828
    Glad to hear it's working out for you. I'm surprised the 24 tooth pinion didn't fit. Maybe you can drill on the gear case to give the motor more swing?
    1,426
    or i should just finaly buy more pinions lol
    im not certian it was a 24t pinion or not . i got it out of my mustang vxl
    other than that its a good motor (but not the best)
    thanks
    South of St Louis
    4,992
    Quote Originally Posted by Oaks View Post
    I've done that before, with my dremel and it worked like a charm.
    1,426
    yep i was bored yesterday and did the mod on the trans case .had to remove the rear bumper becuase the motor can was touching.other than that it went fine so i was geared 24/90 with 2.8 trenchers and the battery held at 10v with a 2200mah charge (nice for a stock nimh). so first run it still had good torque and a decent speed but at 90+% throttle there was a weired rpm noise from the motor .so at the end of the run the motor didnt seem eny warmer then when it was geared 19/90
    but im not going to run this gearing for a while till i get some upgrades and another motor(whats recomended i cant solder)
    so i need to decide if i should get upgrades or finish saveing for a merv? (whats your opinion?)
    so far by the end of next week i shold have around 85-100 bucks
    hey guys is 65 bucks good for a new spc 2s 6000mah lipo?
    1,828
    Im not one to recommend what someone else should do with money, but depending on your motor and esc plans - I'd say the entry level SPC packs should work well for you. 5000 mah, 25c 2S $30. 5000 mah 25C 3S $41.
    1,426
    oh i got the owner of my lhs to just price check the spc 2s 6000mah lipo and a month later he called me saying it was in(self thought of oh no) a couple months ago . any ways its in his shop ready to go for 65 bucks and cells are at c1)3.85 an c2)3.86 as of last week
    as far as the pede upgrade or merv. the pede would be the fastest turn around(rpm front bumper ,strc hing pins, spc 2s) compaired to the merv at 310 +tax
    the way moneys going for me i would probably get the merv as a christmas present
    is there eny other motors that are long lasting and durable that dont need soldering?
    thanks guys
    1,426
    so guys with my situation /setup could i gear it at 23/86 from 19/90 with a 2c lipo? i dont want to mess eny thing up yet but from what i hear is that a brushed motor in genaral can be geared up higher on lipo than nimh.
    so far the battery change would be 1.6v less but 170 amps or so more lol
    (side note if this motor lives long enought i will give a try on 3s lipo)
    1,426
    hey guys update.
    motor still going strong and now its on 2s lipo. what can i say it dosent have the top speed it used to have but it holds voltage under load so well.
    so far with the spc 2s 6000mah lipo. all i have done is half runs on the battery it lasts so long
    (i usualy get 15-20 min on 2200mah 7-cell nimh)with this motor im probably getting 60-70min run time lol more than i need
    and the motor got a little warmer but probably do to the extended rung time
    oh and on another note there was a seconed hitachi drill that the teacher gave me at the end of last school year i finaly opened it up and the motor is dead(well i dont know if it is or not but the hole interior was black and there was 2-3 mm left on the brushes)
    so the next motor will probably be the cc 3800kv ,titan 12t or another odd motor like the one i have
    bye
    ryan
    1,828
    Glad to hear you success story with lipo and the hitachi. Just having the ability to run for an hour without failure speaks volumes to the durability of that motor. You don't always have to go fast to have fun later
    Colorado Springs
    1,848
    i would say, play with the gearing. If you can get a larger pinion on the shaft, use a smaller spur gear. Your motor has tons of torque. try a twenty something pinion gear and a 70-80 spur....bottom line....want more topend, use larger pinion and smaller spur. want torque, use the smaller pinion and larger spur. if you drastically change the size of one, change the other one the opposite way to fit
    "Red"
    "Who wants a Rod that you cant Mod?!"
    1,426
    ya ive put on the 24/90 gearing but that was with the nimh battery i will have to try it with the lipo and see motor temps do
    but yes i will have to try and get more pinions and spurs for the motor to fully unlock its potential
    well oaks lipo and the hitachi havent been together that long maybe 3 half runs (i just get bored after a half run or more)
    but if i could get a 3s lipo i would deffenently want to try it but that will probably be next year
    oh yah 775 posts lol(motor size)
    1,426
    okay tongiht went out with the pede an finaly ran a full 6000mah pack on... 24/90 gearing
    so far only had to take one stop to let it cool off other than that i think it goes faster than it did on nimh for same gearing
    part 2 tomorow
    1,426
    well i dont remember what i was puting down for part two
    but got in the door a couple of hours ago from a dirt mtb park so far only a shell and a motor
    motor lol last fuw mins was running fine looked like it jamed once or something and then quit on me a minute latter
    so got the motor out and it was in full rotor lock for some reason
    so to invesigate and to make money go further i took the sealed hitachi apart and found nothing not even dirt. i put the rotor from my titan 12t motor and made a hitan(hitachi case an the titan 12t rotor ) motor for a couple minutes worked good for just reving.
    then thinking lets try the hitachi rotor and worked perfectly(side note i have about 4-5mm of brushes left oh ya its here to stay)
    so what could have cuased this to happen on a sealed end bell motor?
    and lipo with this motor is awsome on 24/90 gearing just have to take a break half way throught the pack 6000mah 2s lipo
    1,426
    well guys i think i almost fried the motor. just after open rotor surgery
    well out for bashing gear the 24/90 on trechers after half the pack i put my finger up to the motor and lets say i felt the heat before i touched the motor
    so got some water and cooled it off didnt steam but you could defenently here it (like the sound when you pore water on a hot frying pan)
    going out in a couple minutes and see how much torque i lost
    still a good motor
    South of St Louis
    4,992
    still a good motor
    That gearing is probably way too high for a brushed motor. I'm thinking 16 or 18/83 would be about right.
    Sent from Tapatalk version 3.14159265359
    10,186
    Start with 90/16 with the trenchers
    LETS GO PENS!!!!
    1,426
    well ....
    i ran the 24/90 gearing with the stock shell on street but what made this special is i had put on a plastic injection mold shell on(alot hevyer than lexan) and went thought a feild this time.
    normally its on street with a lighter shell
    so far the motor now heats up on 19/90 and hopefully this x mas it will be replaced with the cc mmp sct race pro
    South of St Louis
    4,992
    Can you have Christmas in September?? I couldn't wait that long.
    1,426
    no i need hing pins,shell ,chassis and another 70 for transmitter an 2 rx's(in for warrenty)
    plus other parts to modle the three chassis's for the rustler
    rrrrrr wallet malnutrition
    1,426
    om... guys umm i acutally thought i was running 24/90 with the hitachi 14.4v on trenchers since day one of installing the pinion but it was acutally 28/90 no wounder the trans neede to be cut a little
    holy stress. but even at that it needed a little break(10mins) after every 3000mah's on the lipo so its defenently a good motor sides for the suden overheat that i put on it with a heavyer shell
    so umm ya umm it can do 28/90 quight well lol
