Great information here! I was originally going to buy a set of foams but everyone talked me out of it (
http://traxxas.com/forums/showthread...2-VIDEO-106mph).
I had issues with my 4 tec nitro and the stock slicks that it came with. Now granted, the XO1's are much wider, they are belted, and look like a 'stickier' tire due to a different compound used (I think). However, when given full throttle my car will lose control on the xo1 tires. I just noticed that I had 2 huge flat spots in one rear tire and a possible broken belt. When going over 50mph I heard a rubbing noise which turned out to be the rear tire ballooning and rubbing the side plastic chassis. I put the car on a stand and monitored the stationary speed (traxxas app) and sure enough the rear tire was shot. I think this is why I was having such issues with spin-outs when I would go 60+mph. The drivers side rear tire would balloon, rub the chassis, then cause the other wheel to put down more traction and cause the car to loose control by pulling to one side more immediately.
So back to the foams... I have used foams on my 4tec nitro 3.3 (64mph) with ZERO issues. They work excellent on the street and I could control this car perfectly on a narrow 2 lane road in my neighborhood opposed to the stock slicks. The XO1 is a different story though, lol. It may be because of the ballooning/chassis issue though... I'll have that solved when my new set of xo1 wheels arrive this week. A wide open area is key... but if the foams offer additional traction and control it's a win win situation... especially if they're 1/2 the cost of a stock set of xo1 wheels.
If you get a chance, try to post up some pictures as well as a video if you have one with the foams. As mentioned, you do have to correct the wheel diameter otherwise you will get skewed readings. It is possible to calculate the difference. The higher speeds the higher your mph will vary.
As far as top speeds, if you can register 90mph on your telemetry and you are not spinning out then you're doing good. I have done a lot of testing with a GPS in relation to the app and I've seen 3-4mph difference below 75mph. I had another spin-out at 70mph and managed to crack the screen on my phone so for now I'm done with using it as a GPS unless I'm running in a completely wide open area. 1000+ft open area's with perfect pavement are not the easiest places to find around Charleston.
I was looking into these foams:
http://www.amainhobbies.com/product_...-Dot-17mm-Soft
For $40/set you can't really go wrong. I think I may give these a shot.
