I have summit springs on mine front and back and the traxxas upgrade shocks.
If i press down on the front, it bounces back alll the way.
If i press down on the rear it will not bounce back. Stops about half way.
On the rear i have the screw tightened so the spring is compressed yet the above happens.
If i lift the car of the ground, indeed the rear wheels have stronger suspension and full range of movement.
If i put a piece of paper under each front wheel and push down distance between front wheels remains the same
If i put a piece of paper under each rear wheel and push down, the papers slide. The distance between rear wheels increases sligtly. So i believe this is why it does not bounce back up as easily because it would have to drag the wheels back together and with the wheight it aint gona happen
IS THIS THE SAME FOR EVERYONE??
I have A arms all around and HR knuckles, and traxxas pushrod, toe in and shafts.
