Results 1 to 19 of 19
    Long Beach, California
    6,718
    How to.......Fix broken antenna 2.4ghz receiver.
    Ever had the antenna wire tip broken off from skidding its back without its lid? and since after that, your signal just never the same as it was before? very frustrated and it cost so much to buy a new one? heres an easy yet simple fixed for it.
    1. cut the metal tube
    2. use a hobby knife and slowly cut the black skin off to its length to expose the braided wire
    3. do the same with the braided wire, be very carefull cuting it as its the final cut, or you'll have to do it all over again.
    4. done, you should have the same signal like it was before.
    1,805
    i noticed on mine the braided wire has to be in contact with the metal tube to get the same range on what it had.But on mine it was just the tube that came off.
    Guide books aren't part of the packaging.
    6,718
    not necesarily, i believe the metal tube is there to give it a stiffness to the antenna tube. i could be wrong but, when i tested it, it was working like it was before.
    newfoundland
    193
    Now I know what to try next - have one busted now . If it works I will be soooo happy .
    LP field
    77
    I have one that is like that but the break is half way down the wire
    6,718
    give it a try, peel it off, its worth a try.
    Florida
    32
    i just did this and i REALLY cant tell the range in my neighbor hood (everything in here runs 2.4GHz) so i will let you guys know when i go to the park or out in the woods. but so far seems to be a bit farther then before.
    Florida
    32
    Quote Originally Posted by JDM_summit_vxl View Post
    like i said i tried it and this guys plan to fix the range for a broken antenna works. range increased by at least double from before. NOT SUPER FAR but a good distance. Here are some pix of what i did from what it was before.
    Before
    dont have a picture of the broken metal tube or the broke plastic end. BUt look at the length difference.
    AFTER
    As you can notice, i was able to save a small piece of the metal tube.
    6,718
    you dont need that metal piece that clamping the wire, that will cause cut off signal from time to time, you can cut that off.
    Florida
    32
    i tried it without the metal and it didnt really change. it came with it and i was able to use it again so i did.
    6,718
    look closely and tell me if you can see my antenna.....almost like i dont have one standing
    North Central OH
    1,047
    I don't think you ever want to 'cut' or remove any part of this antenna!
    From the owners manual:
    IMPORTANT RADIO SYSTEM PRECAUTIONS
    • For maximum range, always point the front of transmitter toward
    the model.
    • Do not kink the receiver’s antenna wire. Kinks in the antenna wire
    will reduce range.
    DO NOT CUT any part of the receiver’s antenna wire. Cutting the
    antenna will reduce range.
    • Extend the antenna wire in the model as far as possible for
    maximum range. It is not necessary to extend the antenna wire out
    of the body, but wrapping or coiling the antenna wire should be
    avoided.
    • Do not allow the antenna wire to extend outside the body without
    the protection of an antenna tube, or the antenna wire may get
    cut or damaged, reducing range. It is recommended to keep the
    wire inside the body (in the antenna tube) to prevent the chance
    of damage.
    6,718
    Quote Originally Posted by kwitty View Post
    From the owners manual.
    • DO NOT CUT any part of the receiver’s antenna wire. Cutting the
    i know exactly what the manual says and clearly understand it, but heres the thing about it,...... traxxas protect their product(s) as for warranty wise.
    New York State: Snowbelt
    747
    Humay, pm me
    19
    Kinda reviving here, but I want to be clear before I go doing anything. I ripped the metal off the end of my RX, leaving the wire that went through the tube still intact. Can I use a metal tube, put on the end, making contact with the braided shielding, and have it working correct again? As in, there is nothing fancy with the tube on the original one?
    Dan
    EDIT; Upon a little more reading, I see that the length of the tube, and the length of the wire should be the same, at 3.125 CM. I'm thinking thats the important part, so I should be able to fix it.
    6,718
    Quote Originally Posted by Dan73-07 View Post
    Dan
    here a picture i just took, the cut was after the metal tube....then peeled off the black skin and then the braided skin. the wire tip length is less than inch.
    1,805
    I believe you but put a vid on, as pictures don't show it working to the same good range.
    6,718
    6,718
    here another video of me walking away a block down. http://www.youtube.com/watch?v=h0SV3...&feature=g-upl
