Results 1 to 16 of 16
Thread: Soap and water
    696
    Soap and water
    Will soap and water clean the head of a 3.3 thats all i have right now. got some mud in the center it needs to get clean.
    Usquam sed hic
    1,568
    That will work fine, just set it out in the sun to dry after you finish.
    Do you not have any Windex or anything like that in the house?
    Matthew 7:7
    696
    i got windex, 409, and wd40
    Jul 2011
    S. Jersey
    713
    I've used 409 before it works pretty good.
    Jato 3.3, Revo .28 JL Max, Nitro Stampede 3.3
    696
    i just used carb cleaner. is that good?
    May 2006
    Dayton Nv.
    3,181
    I use simple green myself but 409 works good too.
    Riverton Utah
    4,343
    I just take the head off and rinse it off with Simple Green. You can use simple Green on anything and it works great! (Just don't put it on the body shell, it will make strange color differnces in the reflection!)
    Usquam sed hic
    1,568
    I use windex, just to be on the safe side chemical wise. It has alcohol in it to help the fluid evaporate so it cleans grime pretty well.
    Matthew 7:7
    May 2006
    Dayton Nv.
    3,181
    That's what I use spray on simple green and use an old tooth brush.
    696
    i just used some carb cleaner
    Usquam sed hic
    1,568
    Quote Originally Posted by slayer3.3 View Post
    What ever works for you man
    Matthew 7:7
    696
    Ok thanks sounds good. thanks to everyone who helped
    Oct 2005
    South Florida
    18,468
    Some carb cleaners are OK, others will hurt plastic...
    Wd-40,,, Works, but leaves an oily residue that dirt likes to attach to... Simple Green is excellent but break it down with water, straight Simple Green will take off anodizing in time... Denatured alcohol works well but you should wear protective gloves and use it in a place that's WELL ventilated and NO SMOKING around that stuff.
    Me, I use Simple Green 30% and 70% water in a spray bottle and some compressed air...
    But watch out with cleaning.... Avoid your bearings and places where screws are used with loctite.... Most detergents will strip any bearing of their lubrication and will break down loctite easily...
    Founder of H.U.A.
    Hop Ups Anonymous
    Usquam sed hic
    1,568
    I should be dead with all the chemicals that I've come in contact with lol.
    Matthew 7:7
    696
    what is the best way to get a stripped screw out???????
    Usquam sed hic
    1,568
    I'm guessing it's a hex screw? Try a larger hex key size, if that fails to work, if the screw is not counter sunk, then cut a slit through the head so you can use a flat head screwdriver to turn it out.
    Hope that helps.
    Matthew 7:7
