Results 1 to 26 of 26
Thread: Drivetrain slop
    Sep 2009
    Victoria B.C Canada
    5,076
    Drivetrain slop
    So my truck is down for repairs
    Saw this idea a while back just never tried it, untill now. Had a extra gear laying around figured give it a try if it works I will do something a bit better
    But from my first look and feel seems it should work.just did low gear slop isn't
    A big issue in high gear,for me anyways
    Sent from my iPhone using My fingers
    Mountains cant stop me
    they have tried
    Alma, MI
    12,279
    What did you do?
    Jul 2009
    Ontario, Canada
    11,145
    Ive seen the other thread about this and it looked like a great idea... but like jimmie said, Its hard to know what you did without an explanation or other pics. I remember a bit from that other thread but not enough to spot the differences.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Sep 2009
    Victoria B.C Canada
    5,076
    I will do a better job in a bit here
    they have tried
    Alma, MI
    12,279
    Thanks, Jamann.
    From what I think I might see, it is stronger than the other mod I have seen to these gears to remove the play.
    Sep 2009
    Victoria B.C Canada
    5,076
    The vid is far from high quality but you get the idea
    http://www.youtube.com/watch?v=4Tgz1...e_gdata_player
    they have tried
    Sep 2009
    Victoria B.C Canada
    5,076
    Well I have run it a few times (not with brushless) working fine.a definite improvement just better control and the roll back is reduced quite a bit.
    It doesn't get the chance to build up momentum before it catches. So the roll back is much more predictable and controllable. It's not a worm geared axle by any means but much better.
    On a side note the hub mod is also working quite well
    Sent using magic and trickery
    Ok it was Tapatalk
    they have tried
    Chehalis, Wa
    436
    I like this way a lot better then the other sloppy fixes. This way can be reversed if needed. The other ones involved cutting and shaving that is not reversible unless a person buys a new gear set. I will be trying this. Thanks jamann
    Lol. Don't feel bad. Traxxas has had my rx and tx and motor sense the 11th. The sad part is I still haven't herd from them yet. Grr.
    Sep 2009
    Victoria B.C Canada
    5,076
    Mine is glued in its there for good
    The gears are cheap at least.i looked at the other one and decided to try this one for two reasons.
    1) no real shaving or cutting the gear at all.Easier I like the kiss method of things
    2) The other way it only engages 180 degrees apart so in two spots this way it's every 45 Degrees in 4spots
    I am quite happy as either way you do it it helps for climbing.
    Oh how the mighty have fallen.....
    Stock Titan, evx2,(that's new at least) AM radio,giant eye ripping,branch catching,tangle up in anything thats even close antenna Flailing around
    I miss that radio badly
    Lol
    Ok it was Tapatalk
    they have tried
    nevada, mo
    286
    just watched the video and i will be doing this to mysummit verry soon thank you for the info i was wondering if all the slop was normal i got my summit used and did not know much about the truck
    Sep 2009
    Victoria B.C Canada
    5,076
    Update need to use stronger glue
    The tekin overpowered it and chewed it to dust...lol.didn't break anything just chewed the piece of styrene to dust
    Ok it was Tapatalk
    they have tried
    Sep 2009
    Victoria B.C Canada
    5,076
    Here's how it looked ,except with lots of white styrene dust,lots of it.looks like it snowed inside the trans lol.there was two of those pieces.glue let go.the one left should be in the middle.the other became plastic snow...lol
    lost low range
    I guess Need better glue...lol
    Ok it was Tapatalk
    they have tried
    nevada, mo
    286
    well at least that was the only problem. my wife has a wheely king that lost a tooth in the trans we heard it clicking and keept running and ended up lossing all the gears in the trans. so i will defiantly find some SUPER glue lol thanks for the heads up
    2,011
    Next time you do it make a plastic mold of it (plastic mold kits sell for $20) at hobby lobby and viola, instant all plastic no slop gear. Just as indestructible as the plastic original. And a lot of summit owners lining up to buy a high and low set ($18 shipped).
    MAN, Use Common Sense
    Funky Gecko, SumVee HDE
    2,011
    Second idea. If you don't want to go into business than skip the styrene and fill the whole with J B weld. You can shape the two part epoxy before it dries and it will be as strong if not stronger than the original gear.
    Sep 2009
    Victoria B.C Canada
    5,076
    Quote Originally Posted by noir 522 View Post
    that was my next thought jb weld...i like how you think. more permanent.i like the slop removed in low gear just makes it a little more controllable.
    they have tried
    nevada, mo
    286
    Where do you get the gears?
    Sep 2009
    Victoria B.C Canada
    5,076
    Those are the stock trans gears.Was fine until the tekin came out to play.the dewalt evx combo was doing fine
    Ok it was Tapatalk
    they have tried
    Toronto
    2,324
    For what it's worth, I should mention that if you add jb weld or anything similar, you should try your best to make it 180 even as to keep the gear balanced. You don't want one side heavier than the other, or it'll be very bad on gear mesh and every thing else. =)
    Jul 2012
    the middle of nowhere
    419
    To anyone who's done this, how much harder is it to shift gears?
    Sent from my iPhone using autocorrect
    Sep 2009
    Victoria B.C Canada
    5,076
    When done correctly it shifts normally
    No difference except the majority of the slop is removed.
    Sent using lipo power
    they have tried
    2,011
    does the truck need to "roll" a little further before the gears actually mesh during shifts?
    Sep 2009
    Victoria B.C Canada
    5,076
    Not really any more than before.
    Like I said it is pretty much the same
    they have tried
    Jul 2012
    419
    I may have to give this a whirl. I crawl mostly and I think I could benifit from this little modification.
    Apr 2013
    Ontario, Canada
    778
    Are you still using this mod Jamann? Any updates on whet your currently using in the gear?
    Sep 2009
    Victoria B.C Canada
    5,076
    I haven't found plastic that will stand up to the forces being applied to it yet.
    LEM is said to be working on one
    they have tried
