hello
I wanted to know if they can install on the x0-1 Integy Hex Wheel Hub 17mm 18mm
http://www3.towerhobbies.com/cgi-bin...?&I=LXYWE1&P=7
thanks
hello
thanks
dont think they will work unless you modify those hex to fit the xo-1 axle ... that look like it uses the pin that goes under the hex kinda like my AKA 17mm i use on my slash .. the XO1 doesnt have a pin but the setscrew and its spaced out on the axle ..
why are you looking to change the axles ? somthing wrong with stock ones ?? wish traxxas would of them in that color though
XO-1,SLASH 4X4 ,SLASH 2WD , 2/RUSTLER
the only thing you can probably use off those are the nuts that hold the wheel on .. you have no way to mount those . and those are for a savage .. Im pretty sure the stub axles are differnt sizes .. But if you dont believe me buy them and try it out
i have a similar integy hubs on my erevo
i use TRA4955 pins and it's fine. just don't forget to use threadlocker
My mini E-Revo.net and the BIG ERevo.net
