So I finally got my pre reqs done to the pede for the 3s lipo. Got the gh alum gearbox installed and picked up a thunder ac680 charger. Like I said I want to go with a 3s lipo around 5000mah over 20c and I want to stay with a hard case. Looking to spend around 50-60 bucks. Been eyeballing the gens ace 3s 5000mah 40c hardcase for 50 bucks. The problem I'm having is with fitament. Ive found several lipos that fit length and width but nothing that fits height wise in the stock tray. It's a newer pede so the ribs are out of the bottom of the tray and I guess I have like 26mm to work with height wise. I really don't want to have to raise my body by using the esc raiser however I don't have a dremel to modify my chassis to fit so I think I'm stuck raising the esc till I get one. For some reson I can't find what my clearance will be anywhere online with the 3725x expansion kit. I see the height listed as 36mm on some sites. Does that mean that is the amount of height I get when installed? Most of the 5000mah lipos I've seen are around 38-40mm in height. Can I sand or cut out the supports on the bottom of the esc tray to get a little more room? Anyone recommend a specific lipo meeting the size requirements (138 x 46 x 36mm I guess?)
Thanks for the replys. Can't wait for that 3s power and runtimes.
