+ Reply to Thread
Results 1 to 17 of 17
    Nov 2011
    Planet Vegeta
    651
    motor temps too high
    ever since i replaced my old 12t motor with a new 12t, the new one keeps overheating too quickly, please help
    All I need now is to set a new lap record.
    St. Louis, MO
    655
    Motors go bad for a reason.
    Check your mesh.
    If you are off road, especially grass, go down a gear size and never use the 23t pinion. If you are using heavier wheels/tires or 1/8 scales you will need to go down a few teeth on your pinion.
    Check your bearings. Since winter is over and I bet you ran out in the snow/rain and didn't wd40 your shafts/hubs they might be siezing up. It doesn't take much rust/crud to wreck the outer shafts and bearings(experience.)
    Check your slipper clutch and make sure your pads are not scorched(real shiny.) If they are hit them with an emery board or sand paper. You may want to also replace the spring.
    If none of that seems to help, it is time to crack open your tranny and clean it out and check those bearings.
    VXL Slash 2WD, VXL Stampede 2WD, and E-Maxx 3905
    Nov 2011
    Planet Vegeta
    651
    im only using the stock gearing and i run it on road but that still, happens, and it is new
    St. Louis, MO
    655
    Now that I think about it, having been on here for 42 years, some motors are just bad.
    Did you break in your new motor before you put it in?
    Wet break in process: Take your motor out and hook a C battery up to it and put the motor in a cup of water. Once the battery is dead repeat the process with new water if it has stuff in it and a new battery.
    Dry break-in process: Mount motor and leave the pinion gear off. Connect battery and power on transmitter and esc. Turn the throttle trim all the way forward and dial back a little. Run this for at least 15 minutes.
    I always preferred the wet method since the fans would force out any debris that was in there.
    Nov 2011
    Planet Vegeta
    651
    my dad wont let since my old motor went bad and he thinks its water, but it was the brushes, and he doesnt want to put it in, and my first motor was never broken in water, and it worked better than my second
    St. Louis, MO
    655
    Those traxxas 12t motor don't have a very high tolerence. You could buy 10 at the same time and they would all be different. You could always get a 15t monster from an old brushed emaxx and try that out. My nephew was burning through 12t's and I gave him all my old emaxx motors(I don't know why I had so many) and he is still using the first one he put in it a year ago.
    I can ask if still has them and mail you one. He is over at my house right now, so I will ask him when I get home from work.
    Nov 2011
    952
    Call Traxxas customer service, if it is that new you have a good chance for some courteous help
    Make sure to check wheel bearings as well just in case you have one dragging along.
    Mar 2003
    Wherever the road takes me.
    36,169
    Quote Originally Posted by gientsosage View Post
    For the record, Traxxas does not recommend the water break in method:
    Quote Originally Posted by Nitro Chicken
    It does give the motors more power but remember the magnet debris? This is becuase the water break in method causes extremely accelerated wear and reduces motor life by quite a lot (in spite of what you may have heard). It is a racer trick because they really don't care about replacing motors so long as they get more speed and power for their race. Traxxas does not recommend it.
    Further, the recommended break in process is as follows:
    Quote Originally Posted by Slash Manual
    The Titan 12T motor will benefit from a short break in period to ensure optimum performance and longer motor life. For the first battery pack, use the stock installed pinion gear and drive smoothly on a flat, paved surface. Accelerate smoothly (avoiding full throttle starts), with most of the driving being done at higher speeds. This will help insure that the motor provides the best performance and longest life.
    Nov 2011
    Planet Vegeta
    651
    i clean my bearings after each run 3x, and i dont run it until the batt. dies
    Quote Originally Posted by f687s View Post
    and i dont do alot of stopping and going
    Nov 2011
    Planet Vegeta
    651
    finally, 2 days ago my motor ran cooler, but now the tranny has trash, disassembling today
    CT
    111
    LOL a bad bearing in the trans will cause a motor to overheat. Just replace every bearing on the car with fresh ones and keep the old good ones for backup in your tool box.
    Nov 2011
    Planet Vegeta
    651
    reconstructed tranny did the trick
    n. california
    67
    if everything is turning without resistance can the bearings still be bad?
    summit
    tekin 2250
    rx8 esc
    slash 4x4 ultimate
    CT
    111
    Quote Originally Posted by jp86gt View Post
    If the bearings can be heard there bad. If there dry from no more grease they can spin just fine but heat up and drag or seize.
    Nov 2011
    Planet Vegeta
    651
    the sound is caused by an inclined spur, say more about it later
    traxxas emaxx
    Guest
    put water on it!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Nov 2011
    Planet Vegeta
    651
    the disk in the slipper can be bended and may cause the spur to be inclined, a little bent and BAM! noise
