Results 1 to 19 of 19
    Portland OR
    381
    how fast will the mmp2400 get this truck to go? what gears?
    So i've been running 17/54 gearing and the motor doesn't even sweat. Works good for off road, but of course I have to see how fast it will go. 3s 4000mah traxxas battery is what I'm running with. What is your experience?
    Austin, Texas
    825
    http://scriptasylum.com/rc_speed/top_speed.html
    Select Slash 4x4 for the gear ratio in box 1. Put a 1 in box 2. Then fill out Spur, pinion, battery voltage, kv of motor and tire diameter. This will get you close to the top speed you can achieve. Ballooning of tires will increase top speed (and heat) quite a bit, so keep that in mind.
    RC Turnbuckle Jr. RC-Fan's Avatar
    Jun 2010
    Miami, Fl
    6,510
    if I still remember right when I clocked mine with that set up it was around 42mph.
    FLM - EMAXX
    Central Florida
    555
    18/54 with trenchers on 3s I've gotten mine to 52mph with gps confirmation. One day when I'm not feeling lazy I'm going to put in my 21/50 gearing and run 4s on it
    ERBE, Sl4sh MT, P4de, 1/16 Grave Digger 4x4
    Portland OR
    381
    Quote Originally Posted by RC-Fan View Post
    Think its doin 50, seems just as fast as my Merv on 3s. Got to buy some bigger pinions cause I know I hit rpm limit not lack of power.
    Drove it in my work parking lot that was almost dry having a blast at half throttle or more/ top speed runs trying to drift through a wet patch. 17/54 didn't even get warm. Stock it would have been quite toasty with tonights session. Wish they sold bare and you put in your own electronics
    Houston, TX
    627
    I haven't done it but it will go 80+mph on 4s geared 25-26/50
    Mines geared 20/54 on 3s 5200mah 25c w/ 1/8 buggy wheels/tires and its doing about 50mph and it just get warm. Motor temps around 125F - 130F and the ESC doesn't really register any heat with the finger test, maybe 90F - 95F.
    Portland OR
    381
    Thanks allot, I'll play with that site
    Jan 2009
    Sweden
    487
    With proper gearing and 4s Lipo like i do, it is a INZANE truck... =)
    Stampede 4x4 4s | Stampede 4x4 1/12
    Portland OR
    381
    Does the mamba max pro have thermal shut down? Since it can handle 6s do I only have to worry about motor temp?
    Rotterdam, Netherlands
    6,258
    Quote Originally Posted by braaap58 View Post
    It does. I never managed to push it that hard with the 2400 that it got hot or even close to. Even with the 2650 that isnt an easy job. Awesome controller.
    Portland OR
    381
    can anyone say what gears they use for 3s speed runs. I don't really want 20 bucks worth of gears laying around after i figure out what it will top out at. 17/54 is great and that will be standard, but i want a 1 set for showing off at work.
    Austin, Texas
    825
    eBay sells rollers for $150. You add wheels, body and electronics. It's really the best way to buy.
    Central Florida
    555
    I ran 18/54 with untaped trenchers on 3s and got it to 52mph before I ran out of street.
    736
    Well, if you are trying to run fast on the straight, you need much more then just gearing, to prevent blow over....
    10
    I strapped a gps to the back of my Stampede and checked my top speed. Running mostly on dirt my top speed so far is 38.6 mph. I'm a little disappointed. With better tires and different gearing it will go faster. I'm running the Castle Creations Mamba Max Pro SCT ESC and Neu-Castle 1415-2400kv motor combo, SPC 11.1 volt 5000mah 3s lipo battery, 17 tooth pinion, 54 tooth spur gear, and 4.9" Pro-Line Masher 2000 tires.
    Portland OR
    381
    thanks for sharing, looked like to short of space and bumpy to reach full potential. These suckers are a blast on smooth gravel to go fast. I got a 21 pinion and a 52 spur to try out next. Got to put on street fighter tires to test it. I'm thinking I don't like them cause you can flip so easy turning.
    10
    You are correct. Today i found a straight street with no traffic and made a couple passes. I put the stock tires back on but left the gearing 17/54. The fastest speed with the body on was 48.2 mph. Without a body it hit 50.3 mph.
    Central Florida
    555
    I converted to slash mt, here is my speed with taped trenchers, 21/50 on 3s. I will probably try it again with my untaped trenchers and see what happens
    Also a couple pics of my setup, so you can see it is not lowered or setup for speed runs in any way.
    Portland OR
    381
    Thanks for sharing, I think 4s is the natural progression for my pede. Don't think crazy fast should be a problem with that.
