Results 1 to 19 of 19
Thread: lockers
    696
    lockers
    Does anyone know if there are lockers for a slayer. if so post a website where to find them. thanks
    May 2009
    Edmonton, Alberta
    3,603
    There is a Traxxas Revo Spool available, not sure the part # but im sure its easy enough to find @ buytraxxas.com
    May 2006
    Dayton Nv.
    3,181
    It for the revo but will work in the slayer
    Traxxas Revo Spool
    SD California
    905
    Spool in a rc car IDK about that one. Mabey for a crawler but not something like this. The dirt will need to be soft, no more street running.
    Putting the water on the hot stuff
    9,703
    There's a reason why you don't hear much about them: they snap axles or themselves twist. More in the Revo due to the size of the tires but others have used them in the Slayer with the same results. Go with a thicker fluid...some have used Silly Putty...
    Boise Idaho
    43
    i had bought my slayer used. The previous owner had put a spool in it. It was flippy on pavement, and i had to run the slipper real loose on dirt to keep from spinning out on turns. I soon realized that the spool was not original and i replaced with the stock diff and 100k fluid. Now it behaves much better, both on and off road.
    Oct 2011
    naptown
    588
    i have a spool in my slayer pro and i just twisted my second cv shaft same side both times. lol. mpi makes a steel cv shaft for the slayer pro. getting around to order some this week. mainly because i plan on converting to electic. but i have extra cv shafts made up just need to swap axle stub end and your ready to go again.
    Edmonton, AB Canada
    480
    most all revo parts are same as slayer pro.. the diff spool for revo works. same diffs in slayer/revo. amainhobbies
    Edmonton, AB Canada
    480
    mip makes one for the slayer.. not the slayer pro with wider stance.. i have a youtube video for what parts u need to get MIP for slayer pro. check it out if u like on my youtube channel Ckeithnitro
    Riverton Utah
    4,352
    I don't see why you need stronger drivshafts, the stock ones should hold up just fine. But if you feel like it, you can get the MIp drive shafts IF you have the normal Slayer.
    Edmonton, AB Canada
    480
    ive twisted 2 left and 2right one's right up off the pins.. with the piccos
    Riverton Utah
    4,352
    Maybe you should loosen your slipper clutch just a tad... But with the piccos, it might not help... LOL.
    Edmonton, AB Canada
    480
    lol.. slipper is fine. when u get a big block u'll know.
    Riverton Utah
    4,352
    That is, IF I get a big block... I plan on it, but you just never know...
    Edmonton, AB Canada
    480
    my next rig will be a 1/5 hpi baja5SC to mod out..
    Riverton Utah
    4,352
    GASP!!! YOU TRATER!!! JK!
    Edmonton, AB Canada
    480
    LOL want an nitro 1/8 ofna Dm-1 spec kit version also.. I have a .28 engine and race pipe for it already..
    Riverton Utah
    4,352
    Ok! I understand that... What ever floats your boat! Or whater ever makes your 4 wheels turn... LOL!
    Edmonton, AB Canada
    480
    traxxas part #tra5381x Amainhobbies.com where are u located?
