+ Reply to Thread
    delaware
    50
    mah = how much run time
    i know that the mah on the battery is how much run time that you can get out of the battery.So dose any one know the scale. like 200mah = 1min or something like that. i am useing the stock brushless system. Dose any one know?
    kansas
    6,307
    which truck? one batt or two?
    parellel or series
    Batts in series double the voltage:
    2x 2s 20c 5000mah = 4s 20c 5000mah
    Batts in parallel double the mah capacity:
    2x 2s 20c 5000mah = 2s 20c 10,000mah.
    Pittsburgh
    728
    parellel or series
    40C when you are running 2 20's in parallel because each pack can handle a max of 20 and the current from each battery only flows in one battery.
    20 in series because the electrons have to flow through both packs.
    0111001101101001011001110000110100001010
    delaware
    50
    Slash 4wd one battery
    Pittsburgh
    728
    Quote Originally Posted by isaiahdaplaya View Post
    Quote Originally Posted by Westgraphix View Post
    I get 25-30 min run time at the Track with the ******* 2S 5000mah batteries.
    Quote Originally Posted by madkawi650 View Post
    I'm seeing 20-25 minutes on a ******* 2S 5000mAh and more than 25+ on my ******* 2S 5200mAh bashing in my back yard.
    Quote Originally Posted by healthyfatboy View Post
    I used stock gearing on a high traction indoor cement track and got 25 minutes plus out of my 5000mAh Venom 2S LiPo.
    From another thread.
    Jun 2006
    Stillwater, MN
    1,606
    Quote Originally Posted by Cipher_Jones View Post
    Technically it's still 20c when running two 20c packs in parallel, you do get double the discharge amps but it would be 10,000mAh @ 20c
    Capacity x C rating = continuous amps
    20c 5000mAh = 100 amps
    20c 10,000mAh = 200 amps
    Revo.27TX/Jato.18/Maxx523/Maxx3.3/GMAXX/Rusty/ERBE
    delaware
    50
    Thanks for the responses
    Bethlehem, PA
    218
    I just purchased an 2S 8000 mAh Lipo - the thing is amazing. It gives me 55 minutes of drive time. I run it for 25 to 30 min, then I give it a break. When everyone runs inside or back to their table to charge their batteries, I just let my fans cool my motor and ESC - no charge is needed, because I can run another 25 to 30 minutes...
    So worth the money - I payd $72:
    http://www3.towerhobbies.com/cgi-bin...&I=LXBPHA&P=ML
    You will need to spend $6 on a battery expansion for the Slash 4x4:
    http://www3.towerhobbies.com/cgi-bin...&I=LXUVZ8&P=ML
    I hope this helps!
    Mayor VXL
    ERevo|XO-1|Summit 1/8th
