FS: Traxxas Jato parts HALF PRICE With FREE SHIPPING a ton NEW
hi guys i have up for grabs today a tonnage of new in packs Traxxas Jato 3.3 Parts, over $300 worth of stuff at less than half the price, and with free shipping, everything listed and in the pics for the first $150 shipped free for all. thanks and have a Merry Christmas. and as for feedback I had to create a new account due to the password login problems, but heres my original screenname with good feedback, and i have a lot more up to date on other sites if needed. http://traxxas.com/forums/member.php?50276-nitrodude711 and heres some feedback http://traxxas.com/forums/showthread...t=nitrodude711
picture links are here:
http://www.rcgroups.com/forums/attac...mentid=5384842
http://www.rcgroups.com/forums/attac...mentid=5384843
http://www.rcgroups.com/forums/attac...mentid=5384844
TRA5544 Bellcrank Posts jato (2) $3.49
TRA5521 Front & Rear Suspension Pin Set jato $5.99
TRA5516 Roll Hoop/E-Z Start Plug Mount jato $4.99
TRA5247 Carburetor O-Ring and Seal Kit TRX $3.19
TRA5276 EZ-Start 2 Complete Gear Set Complete $6.69
TRA4581 Glow Plug Lead Wire (Blue) EZ 1, EZ 2 $1.89
TRA4583 Jato 2.5 & 3.3 E-Z Start Wiring Harness $3.99
TRA5578 Traxxas Anaconda 2.8" Tires w/Foam $14.99
TRA5576R Jato Rear Anaconda All Star Wheel used (2) $21.99
TRA5582 Diff Gear Set Jato $7.99
TRA5579 Differential Gears Jato $6.99
TRA5581 Gaskets, Differential/Transmission Jato $1.45
TRA5514 Jato Front Body Mount $2.89
TRA5534 Rear Spacers, Stub Axle Carrier Jato $2.29
TRA5543 Steering Bellcranks Jato $4.49
TRA5119 Ball Bearings, 10x15x4mm (2) $4.49
TRA4146X Clutch Shoes/Springs (higher stall) $5.79
TRA5228 Cooling Head Protector TRX 3.3 Engines $2.49
TRA3147X Fuel Line (2 ft) $2.79
TRA5549 Fuel Tank Rebuild Kit Jato $2.79
TRA5593 Jato Primary Shaft and One-Way Bearing $15.49
TRA5136X Differential Oil Kit 10K, 30K, 50K opened $13.99
TRA5245X Tuned Pipe Coupler & Exhaust Deflector $2.99
TRA1666 Silicone Shock Damper Oil x2 (30 Weight) $3.58
TRA3232X Super Duty Long Glow Plug $4.15
TRA4976 Wheelie Bar Wheels & Axles $2.79
TRA5546 Tuned Pipe Hanger Jato $1.79
TRA5536 25 Degree Caster & Steering Blocks L & R Jato $3.99
TRA5556 Aluminum Slipper Pressure Plate & Hub Jato $5.99
TRA5530 Front Bulkheads, Upper & Lower Jato $6.99
TRA5518 Front Shock Tower Jato $3.99
TRA5149 Front Wheel Aluminum Spacers (4) Jato $2.29
TRA5562 GTR Shock Rebuild Kit Jato $3.99
TRA5555 Jato L&R Rear Stub Axle Carriers $3.19
TRA5517 Jato Rear Shock Tower $3.79
TRA3956 54T Spur Gear Jato $2.79
TRA4611 Ball Bearings 5x11x4mm $9.98
TRA5552X Slipper Clutch Rebuild Kit Jato $7.89
TRA1654 Stub Axle Pin & Collar: B,S,H,E, Jato $1.79
TRA5464 shock boots (2x2) $4.98
TRA5559 mounts suspension pin blocks $2.99
TRA2055 traxxas 2055 high torque servo new $18.29
TRA5261 Air filter insert foam $2.00
Traxxas GTR complete shock set new (4) 1 used $30.00
and some decals for $free
This add has been edited. Per the Market Palce rules only Traxxas items may be bought, sold, or traded here. The non Traxxas items have been removed
Dadx2mj
any best offers out there?
i have a jato 3.3 loaded with less than a gallon through the engine meticulously tookin care of i'll throw in for $400 shipped for all. theres over $350 in parts alone.
SOLD BUT JUST NOT HERE, Dont even know why i came to this place. Its absolutly worthless
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
