+ Reply to Thread
    nitro rustler gear ratio with badland rears
    I have a nitro rustler and my stock rears are bald so i want to buy badlands. What clutch bell do i need 18t or 16t?
    Delta, Pa.
    1,167
    What engine you running? What Spur you using? I dont know how you would get either to fit and your carb still clear the tranny. The 20T will work if you are running a 3.3. If you are all stock then badlands arent for you. They will put a tremendous amount of strain on your tranny and most likely blow out your idler gear. With a 2.5 engine it will overheat very quickly. To use badlands sucsessfully you need to beef up your tranny. Not recommended for stock cars. If you are running all stock I would recommend using JC goosebumps. They are the best all purpouse tire I have found yet. Provide more info on your car and I can make recommendations for what you need to do to handle the badlands.
    1,437
    An 18t cb and 72t spur should do the job for you. If the carb hits the tranny just rotate it, I know that gearing will fit fine. Good luck
    http://www.youtube.com/user/shaggy101086
