Results 1 to 4 of 4
    Long Beach, California
    6,607
    Bad idea or good idea.......
    as the tittle says, is it a bad idea or good idea to plug the end of the rudder? and what can happen? i'm just curious if it will improve its water flow.
    thanks in advance.
    Jun 2011
    941
    Not entirely certain what you mean by plug the bottom of the rudder.
    If you are referring to the round hole on the very bottom edge of the rudder that is "left over" from drilling out the galleries, then yes, it should be plugged from factory.
    If it has become unplugged, then you should seal it up again.
    hog
    El Cajon Ca
    1,804
    Yes as hog said ..... you need to plug up the hole in the bottom of the rudder as water will exit there as well and provide less water flow to the componets where it is most needed.
    I have had this happen to me once also.
    "enjoy your ride"
    Dennis
    6,607
    yeah, thats what i mean the bottom part hole of the rudder, lol. mine are not plug in and i did'nt even know that its suppose to be plug. so i use a tiny threaded hex screw, its in there pretty tight.
    thanks hog.
