Results 1 to 23 of 23
Thread: What did i do?
    Chehalis, Wa
    436
    What did i do?
    Ok. I let the daughter play with my summit and some how the trany servo stopped working. So I figured it was time to do a cleansing while I was waiting for the new servo. Well today the servo came and I installed it and got it up and running. Everything works great except that when I get about 60 feet away it just stops. I put new batteries in the remote and fresh charged batts in the summit and still no change. I also found out that when I put the remote behind my back that I have no movement in my summit. When I bring it back front of me I have full control. what when bad?
    Alma, MI
    12,279
    Check your antennas... both the Rx and Tx.
    Also check for dampness in the Rx box.
    Sep 2009
    Victoria B.C Canada
    5,074
    +1 thats the first thing to check with those symptoms is it a am or 2.4 tx
    Sent from my iPhone using My fingers
    Mountains cant stop me
    they have tried
    Newport Beach, California
    516
    Maybe you ate too much lead as a child?
    Bash OR crawl? No, the Summit does it all!
    Chehalis, Wa
    436
    I've checked the rx over and over and didn't see anything out of the ordinary. I have not looked at the tx yet. What should.I be looking for in the rx and tx?
    15,438
    @ jamann: It is definitely a 2.4GHz.
    @ Keila72: Didn't you have water in the Rx box previously? Radios (Tx and/or Rx) have a flat $15 repair/replacement + $5 return shipping fee per the Traxxas Lifetime Electronics warranty.
    Alt-248 on the number pad =
    Chehalis, Wa
    436
    I did have moisture in the rx box and it was working great for about 3-4 weeks and then this happened. what should i he lookjng for in the rx and tx
    260
    check the antenna length in the blue antenna tube beside the receiver.
    you could have moved the cable coming out of the receiver it while changing the servos over (it happened to me before)
    Chehalis, Wa
    436
    Ok. I've tore into my TX and didn't see anything out of the ordinary. I also tore into my RX and didn't see anything wrong either. The only thing I noticed is when I loose signal the red light links on the the RX.
    The RX antenna is all the way to the top of the blue tube an.d everything is spotless inside. I also put a little bit of dialectic grease in there last time I had it apart.
    What is the metal end on the antenna wire in the blue tube? How long should mine be? Mine is 1/16 shy of 1"
    Also. Does the Y harness and light have to be plugged in. I took them out to have them repaired and they are currently not on the rig.
    Sep 2009
    Victoria B.C Canada
    5,074
    No only the esc needs to be plugged in
    Mine has a clear coated piece of wire sticking out of the metal end a inch or so
    they have tried
    Chehalis, Wa
    436
    Do u think thats whats wrong with mine. I have been messing with it all day and still can't figure It out. If that is what's wrong with it is it Fixable or do I have to buy a new RX. My nearest hobby shop is just over a hour away and I want to try everything I can b4 I make a road trip.
    Chehalis, Wa
    436
    Here is a pic of mine. Can anyone look at theirs and see if it looks the same.
    Sep 2009
    Victoria B.C Canada
    5,074
    Sorry I took so long, here is a pic of mine notice the clear tubed section
    It could be some of the issue.if so and you can solder not hard to replace.
    they have tried
    Iowa/ill/KS
    351
    make sure the antenna didnt get pinched by the tube base, if the wires inside the antenna are touching anywhere it will do what yours is, only difference is when i saw it the truck only went 20ft.
    Chehalis, Wa
    436
    Humm. I dont even see or have seen that piece. Where can I find a new antenna wire?
    Alma, MI
    12,279
    Traxxas offers an extended service plan for electronic components after the 30-day warranty has expired. This plan states that Traxxas will repair electronic components, excluding speed controls, at any time throughout the life of the part, for a flat rate of $15.00 plus $5.00 for shipping and handling. The electronic components covered under this service plan include certain Traxxas transmitters, receivers, and servos.
    Other than through this program, that antenna is not available.
    Sep 2009
    Victoria B.C Canada
    5,074
    They don't sell the antenna .bummer
    I replaced my am one a few times.
    Their service is excellent just sent my new tqi back for repair.3 runs and it quit
    they have tried
    Chehalis, Wa
    436
    That's a bummer. I really wanted it for this weekend. What if I didn't buy my summit new. I bought mine used off Craigslist, will it still be covered under warranty?
    Chehalis, Wa
    436
    Well I got my new RX today and just installed It and i have signal now. I've ran it around the house and it works good. I haven't been able to go outside cuz its been raining cats and dogs all day. Anyways. Once I got it all back together I noticed the my front diff lock servo keeps twitching and freeking out. Any ideas why it doing that.
    Chehalis, Wa
    436
    Ok. Been trying to get this thing stop glitching and and people keep telling me that its not synced all the way. So I try and sync the TX to the RX doing how Traxxas says to but when I do that the TX goes to green and the RX stays blinking red. I can shut the esc off and then turn it back on and It works but it doesn't have much for range and the front shift servo is glitching bad. Can anyone help me.
    Sep 2009
    Victoria B.C Canada
    5,074
    First thing I would do is unplug everything from the Rx,except the esc
    Calibrate.everything ok?
    if yes start plugging in one servo at a time until the issue occurs again
    A bad servo has been know to make the evx 2 do some strange things.
    they have tried
    Nov 2011
    Planet Vegeta
    651
    maybe your daughter shifted speeds in a not ordinany fashion
    All I need now is to set a new lap record.
    Chehalis, Wa
    436
    Ok. I got them linked and everything seems to working properly except now I can only go about 150 out and it losses signal. I have to go get closer to get it to move again. Also if it goes behind something it losses the signal till it gets back into sign of sight.
