Page 1 of 5 1 2 3 ... LastLast
Results 1 to 40 of 177
    460
    General information for all.
    I wanted to start this thread because i always have some general questions, that i have a hard time finding direct answers to.
    So i started this thread in hopes i could get more direct questions i run into on usually a daily basis.
    1st question, i stripped my front diff when i installed a alum bulkhead. when installing it i noticed that from the factory my merv came with a small shim on the input gear of the front and rear diffs.
    i've looked and asked around and nobody seems to know or ever seen this before.
    i am going to keep the alum bulkhead, i just ordered a new diff and pinion gear (it was the one that was stripped) and just wondering if anyone knows if i should keep the input gear shimmed or just shim the ring gear. and what size would this shim be? (the input gear shim)
    460
    if you have a question feel free to post it here, i dont care about "hijacked threads" post your questions and answers
    9,245
    By input gear you mean pinion gear. Correct?
    460
    yea.. it come out of the box brand new with a shim on it both front and rear.
    after i put on the alum bulk head and heard it starting to strip i took off that shim drimmeled out the inside hole so it would go on the ring side untill i got some shims for the ring side, and now that i got the shims for the ring comin in, i would like to know about this original shim on the pinion gear that come factory like this.
    if i should put it back even thought i made the insde hole bigger, and if i should but should get the correct shim, what is the correct shim size for the pinion gear in the diff?
    9,245
    Can you take a pic of where you ground it out and post it. Having a hard time picturing it
    460
    ill try to, i have to make a flicker account first right?
    Hamburg/Germany
    326
    From your description, i think you look for 4mm shims (inner diameter).
    Search for Tamiya 53586 4mm Shim Set (0.1/0.2/0.3mm, 10pcs each)
    or Hot-Racing part no. W4X
    Great thread idea, btw.
    Hope it gets traction like the "What did you do to your MERV today" topic.
    edit: flickr or photobucket should work.
    9,245
    The pinion is a 4mm diameter but with a new ring and pinion you probably wont need it.
    9,245
    The hpi z695 shims would fit too. I use those for my axles and under the rocker arms
    460
    ok.. i will work on getting that pic up today
    460
    pics uploading to new flkr account now, for some reason i am trying to upload from my phone and its taking forever.
    then it gets to 99% and says upload failed
    9,245
    I send the pic to my computer then upload to photobucket
    460
    o i thought flkr..
    9,245
    Either will work I hear
    460
    ok uploading from my computer right now... pics coming soon.
    460
    here is the pic of the diff shim on the pinion gear. i bored the inside hole out to put the shim on the ring gear after installing the alum bulk head.
    here is a pic of my makeshift burn wrap, after result of trying to soder traxxas connectors to my lipo, needless to say i didnt do so well, but i tried and tried and burned and burned untill i finaly got it, (dont give up if at first you dont succssed...)
    http://www.flickr.com/photos/7872600...in/photostream
    and here is a pic of my little tool box with extra parts and my merv. man i love this car, and all the help i get from every one.. thanks to everybody.
    460
    http://www.flickr.com/photos/7872600...n/photostream/
    try that link for the pic of the shim..
    crazy how the only link that worked is the one of my screwed up hand..
    how do you get the pics to show up in the thread
    9,245
    That was a big diameter shim. I wouldn't run one with the new ring and pinion
    460
    it come stock on the pinion. i think the pic makes it look bigger than it is, the outside diameter is the excat same size as the edge of the pinion gear.. it sits flush with the pinion as far as diameter
    9,245
    Is it plastic?
    9,245
    Maybe Traxxas shimmed it specifically for your stock bulkheads
    460
    yea its plastic.
    460
    if traxxas done it, then if i stay with the alum bulkhead i should take it off, and shim the ring then right? and if i go back stock then i should reshim it correct?
    9,245
    I wouldn't use it. It might of been specific to the original ring and pinion and/or for the original bulkhead. But with the new bulkhead and new gear set just shim the ring gear
    460
    sounds like the most logical thing.. its crazy though how i've looked all over the net and no where does it say anyting about these shims
    9,245
    Sounds like it didn't belong there
    9,245
    Just had to get off that number!
    460
    haha.. mark of the beast!!! beware!! i would have done the same thing...
    can you tell me how to get my photos to show up in the thread instead of likes like yours do.
    9,245
    Well with photobucket once you upload a photo you click on img,that copies the photo -then in the post control V to paste. Not sure about flicker
    514
    Possibly the best Iron Maiden song
    460
    ok.. i'll get me a photobucket account
    460
    test pic
    460
    correct me if i am wrong, but on my controller i can set the steering expo or trim, and once i have set it i can put the multi function nob back on what ever it was on and whatever i set the other to it will save it?
    and what is it i need to se that makes it turn more when i turn the wheel on my controller
    9,245
    When you set the expo -it stays set - you can do steering, turn the knob clockwise for high speed runs wont be as sensitive to steering changes then turn knob the other way and its back to stock settings. Or program for throttle and its mellows out the hit when you open up the throttle
    9,245
    The other setting is end point adjustment. I am not home at the doctor. When I get home I will tell you how to program that
    460
    ok, cool, cause your first post there you kinda lost me
    9,245
    with the steering expo set and knob full clockwise it decreases steering sensitivity by making the servo less responsive near the center.so on high speed runs if you make steering adjustments they are very small and you won't crash
    9,245
    for steering expo -hold down menu(one green blink)-press set-press set(one red blink)-hold down menu to exit
    9,245
    for throttle expo-hold down menu(one green blink)-press set-press menu(2 red blinks)-press set-hold down menu to exit throttle expo works just like steering expo-on slippery surfaces when you tap the throttle the power is mellowed a bit (less power when you hit it)
    460
    ok.. i got it cool. i know it says it in the book, i just havent tried it out yet..
