Results 1 to 13 of 13
    147
    Camber and toe help
    when i put aluminum knuckles on i just winged it as it didnt have directions and i dont have a camber gauge. today i tried to change it my self. i missed it as all it wants to do is spin out. is there any trick or tip to get it back to stock. by the way its a mini revo.
    so cal
    9,244
    Stock arms or rpm?
    147
    stock arms
    so cal
    9,244
    Try to set the pillow balls to stock setting. Screw in until the threads disappear
    If you have a small level that would help. Leaning in just a bit
    147
    didnt know that was stock. will try thanks for the fast response
    so cal
    9,244
    Some adjust them in all the way then back off 1/4 turn
    147
    It seems better using the first setup. I'll have to see once I get tires that aren't slicks
    so cal
    9,244
    Yep and upgrade to rpm arms. Hot setup!
    147
    Rpm arms for when the t bone doesn't stop the mail box.
    so cal
    9,244
    I hear that and your set with your carriers!
    Pittsburgh
    765
    http://www3.towerhobbies.com/cgi-bin...?&I=LXXLC7&P=7
    You'll want those, or a different version of those. That way you can adjust your toe in correctly along with your alignment. Can't really get both working w/o them IMHO.
    0111001101101001011001110000110100001010
    460
    how would you use a small level to adjust it? i've had this same problem i just go by what the rpm a arms sheet says, but i'd still like to know how to do this with a level?
    so cal
    9,244
    Not the most accurate way but you want the tires to lean in a bit.put on a flat surface, take a small level put on the side of the tire straight up and down. And set it with little bit of negative camber
