Thread: Summit A-Arms
    Saskatoon, Canada
    480
    Summit A-Arms
    Does RPM make f/r a arms for the 1/10 Summit? If so, do they work well? And it there any other issues?
    Thanks,
    Clay
    woodstock .on.canada
    2,194
    yes e revo/revo sept the where the diff locker f/r side is you have to cut the cross brace of the a arm down (same with stock replacment arms) other than that i think there is a problem with the lt rocker just the angl of the push rod due to the lt rocker but i could be rong
    ya 550 cant wait till 775 lol
    ^posts^
    15,595
    Answer is no they don't make them. The front RPM Revo arms can be made to work and RPM does not make the rear extended wheelbase arms.
    Why would you need to go RPM with the arms?
    Alt-248 on the number pad =
    Saskatoon, Canada
    480
    Just wondering, thanks for the help.
    490
    You can use the revo arms, but the lower right (may be lower left) wont clear the diffs. You can use the stocker and replace the rest with rpm if you want.
    Rpm stuff isnt really needed on a stock summit, but I switched my fronts because rpm holds up better is the cold.
    2,194
    sept if you replace the stocker arm with another stock arm you have to cut some of the cross brace
    490
    You do not need to trim a stock arm. Hence, stock.
