    3
    Unhappy tqi transmitter interference problems/jerky throttle
    Just got a new tqi 2.4ghz transmitter with 5 channel telemetry reciever combo. I've calibrated and linked to my castle creations SV2 esc wit no problems. Steering and throttle respond correctly. However when I set the car down on the pavement and hit the throttle the car seems to jerk toward then lose connection/power for a fraction of a second and then jerk forward again and again. After a few seconds of this behavior the car will respond normally even if I increase speed and distance,however, as soon as I realease throttle back to neutral/brake the problem starts happening again. Any ideas?
    Toronto
    2,317
    Recalibrate the TX to the RX, max throttle, etc..
    3
    What exactly should I be calibrating? What settings or parameters? Fwrd, neutral, and reverse seem to be properly calibrated. But from a stand still and at low speeds the throttle is still very glichey. I can grab a fist full of throttle and it edges forward almost nonreponsive then out of nowhere shoots forward so qwick it does a back flip. Lol.
    Alma, MI
    11,971
    Standstill to low speeds is where you are going to experience cogging.... this is because it is not a sensored system; the ESC does not know the exact positioning of the rotor in the motor.
    Melbourne, Aust.
    69
    Have you got the speed control set for high speed timing?
    Changing it may help?
    3
    My motor timing is set to "low". I called Castle creations today and they said the battery I'm using doesn't have a high enough discharge rate and that is what is causing the "cogging" or so they call it. I'm running a Venom 7-cell 8.4 volt 3000mah nimh. I never had this problem with the old sidewinder sct and I used the same battery .
