Results 1 to 19 of 19
    detroit lakes, mn
    20
    upgrade Differentials.
    has anyone tryed upgrading differentials? i know the 3806 has a weak points. like the plastic cup and ring, poinion and not harden. has anyone try these
    http://www.unlimitedengineering.com/...ore/13540.html six spider or
    http://www.unlimitedengineering.com/...re/13540B.html eight spider.
    im just getting tired of taring it down to replaces little parts in the differential is it worth the 350-to 370$
    593
    I bought two of the new E Maxx diffs for $34.00 shipped on EBay. Their a bolt in and should hold up and if you blow one it's about $17.00 to replace the unit.
    The E Maxx 3903, 05, and 08 diffs have internal bracing so those are the best choice.
    $350.00 for a couple diffs
    Jun 2006
    Stillwater, MN
    1,604
    I have two pairs of the 6-spiders and the only thing I've had to do to them in 5 years is replace the bearings.
    Revo.27TX/Jato.18/Maxx523/Maxx3.3/GMAXX/Rusty/ERBE
    Peekskill NY
    232
    Go on Fleabay and grab yourself bonafide 3908 diffs... NO OTHERS!! Should cost you about $17 a pop and definitely your best bet.. Spider 6 UE ultralights gearing will slow your truck considerably and are NOT completely bulletproof...
    EMBE BANDIT VXL SASSY CLOD RC10L RC18MT
    detroit lakes, mn
    20
    those look good suteki. i opened one up last night and there were no striped grears but the lub in the carryer basket was realy realy paisty. it must of got gunked up from the gravel pits we were in. i could see the diff not working if on side of it would become more seazed up from the pasty grease.
    detroit lakes, mn
    20
    i still hear goood things about bullet proof gears. but the ones i find are too spendy
    u.k.
    1,425
    3905,3903,3908 diffs if you want inexpensive upgrade.
    Some you can mod yourself (LST2diffs) for not much more.
    I don't see the need for the really expensive ones.
    Motorcycle/Quad,Think sand vehicle, piggy backs
    Dec 2009
    East central Iowa
    122
    Are the TMaxx 4907 diffs. the same as the 3908? I had to replace both diffs. in my 3908 due to the input shaft bearings failing, both in the same week and the truck is only a few months old. Is this a common issue?
    u.k.
    1,425
    No the brushless/ready maxx's has the I-bar for support and uses a different diff carrier.
    The Tmaxx's don't have the I-bar support, because of the different diff carrier it won't fit.
    Double check in the exploded views first but i'm sure thats right.
    but if you have the 4907 diffs, I don't know how much the new carrier is, maybe a few dollars.
    Dec 2009
    East central Iowa
    122
    The diff. assembly I just installed in the front an hour ago from EBay says it was pulled from a 3.3 TMaxx.
    u.k.
    1,425
    yep mine is too a new carrier and parts is less than £4. I need new gaskets as my fluid has emptied out after checking yesterday. #3978.
    The emaxx has the stronger of the diffs.
    May 2010
    Nova Scotia ,Canada
    1,246
    Quote Originally Posted by phowler View Post
    Yes, when I instal new diffs I replace that inner pinion bearing with an aftermarket bearing.
    detroit lakes, mn
    20
    yep went out today and blew out the front diff. again. and my friend shot out his rear diff. what the @#$@. what will work. give me some links or pics. i run a t8 2000k tekin motor with a rx8 on 6s. all around bad *** truck, but the diff. blow with in ten mins
    May 2010
    Nova Scotia ,Canada
    1,246
    Changing that inner pinion bearing and shimming the diffs should net you some longer run times in between diff rebuilds.
    http://traxxas.com/forums/showthread...-Diff-Shim-Mod
    227
    As Bent pointed out, they need to be shimmed. They are actually pretty good when shimmed. I blew the front diff in the first fortnight. I don't think the outdrives from the spider gears are such a problem, it's the pinion and ring gear that are the culprits. Shim the pinion so the center driveshafts are nice and snug and the pinion has a good hold of the ring gear and you'll greatly decrease the chances of any problems. I always run 6S and since shimming haven't had a problem.
    Also, get off the throttle when coming down off jumps as that just shock loads the pinion up the ring gear and it'll go bang real quick.
    204
    Quote Originally Posted by USARUSH View Post
    Well, I wouldn't know about the UE Ultralights....
    But surely the FLM Hybrid Bulks using 1/8 scale diffs, be it HPI diffs, Caster Racing diffs or other brand, are as bullotproof as they get, even a 6s no worries - it's proven in many builds.
    And surely it doesn't slow down the truck - it's all about the right gearing and your topspeed is the same as using the stock diff.
    Jun 2006
    Stillwater, MN
    1,604
    Quote Originally Posted by petraeus View Post
    Very true, I'm running the stock diffs in my ERBE and even running on 4s I've blown out a few. I have the UE Ultralites in 2 of my Maxx's and Hot Bodies diffs with Hybrids in a third and they've held up great running everything from 6s brushless to .28 nitro. Most 1/8th scale diffs are geared lower but using a larger pinion or smaller spur will give you the same top speed so they don't slow your truck considerably.
    detroit lakes, mn
    20
