Results 1 to 28 of 28
    153
    Castle creations
    If I get the sv2 and 4600 kv motor will I be able to power it enough with 2s 2200 mah 20C or a 3s 1800 20C
    1,717
    Yes, it will get pretty hot with the 3s if you run aggressive gearing. I prefer my velineon 3500 over my CC 4600kv.
    Jun 2010
    Miami, Fl
    6,731
    it will be ok, you shouldnīt have any heat issues, old 4600 can run up to 4s, newer 4600 4 pole motor are stronger, get at least 25c batts.
    1,717
    I ran mine today on ***** 1800mah 20c 3s and after 5 speed passes i could barely touch the motor. Same setup with the velineon 3500 and it barely got hot after a ton of speed passes.
    Jun 2010
    Miami, Fl
    6,731
    Korn how hot? too hot to touch is not accurate, I had 4600, 5700kv, and never had a temp issue, what gearing are you running ?
    153
    I'm not looking to spend any extra money on battery's I just wanna get my car running and go fast it's broke down right now. I was just wandering cause I could get the combo for $100 or I could just get the esc for $60 then gat a tacon ( there finally in stock) idk I'll prolly use my friends Velineon 3500
    1,717
    I dont have a temp gun. And i know touch isnt accurate. But its enough to know my cc 4600 runs quite a bit hotter than the velineon 3500. And i run 31/45 gearing and just do speed passes on the road.
    Jun 2010
    Miami, Fl
    6,731
    of course the 3500kv will run cooler is a lower kv motor.
    Jun 2009
    244
    I love my velineon and that thing only gets hot on 3s after 20min or so of hard running
    Slash, Ken Block Fiesta
    Slash 4x4
    Summit
    Feb 2002
    4,618
    on the same setup and on batteries than can support a 4 pole motor, as they are amp hungy, that castle will run a lot cooler than the traxxas 3500
    running sub-par batteries, is not a good choice
    if you can't afford to make the proepr upgrades, then don't do them
    Ft. Stewart, GA
    594
    Quote Originally Posted by korn0307 View Post
    Korn stop selling me on the velineon I'm so close to buying one lol the price is unbeatable I just hope it will be a noticeable difference between my stock vxl... Now the next question is do I even have to get the velineon esc for the 1/10 since my current one should still be able to power it?
    Whatever I just said.. I'm probably wrong..
    Jun 2010
    Miami, Fl
    6,731
    I donīt think the stock esc can handle a 1/10 motor, it barely supports the 380 motor.
    1,717
    It will be a lot more noticeable than the stock setup lol.
    Feb 2002
    4,618
    Quote Originally Posted by ArmySSG View Post
    the 3m is not going to work with a 1/10 vxl motor......
    eastvale, CA
    30
    Can the velineon motor run on 4s lipo ?
    so cal
    9,244
    it has been done but not the best thing for it !
    1,717
    The 380 or 3500?
    153
    Ok so I ordered the SV2 and the big block motor plate and mount and I have a Velineon at home waiting to be installed except I forgot to order 3.5 bullet connectors hope the hobby shop has them
    1,717
    You will not be disappointed!
    153
    I'm just glad I got my car running again it's been down for a bout a month and a half but now it will be faster and that means bigger jumps if you have seen my jumping video this next one will be better
    1,717
    BBs are heavy. You are gonna be landing very hard if you jump high with a bb. Specially the 3500! The 3500 is noticeably heavier than the CC 4600kv motor.
    153
    I land in tall soft grass
    thank god
    1,717
    Haha you will be safe then.
    Rotterdam Hoogvliet NL
    886
    KOrn dont like CC enigne anymore
    Xtreme has no limiits
    1,717
    Mossie, I love my CC motor! If i had a temp gun and knew if if was running at a safe temp then i would use it all the time. But till then im not gonna keep running it and getting it soo hot not knowing if im hurting it. I could gear lower but why would i do that when i can run the same gearing with a different motor and not have to worry about it running hot and only loosing 1mph?
    153
    What gearing should I use
    Chould the stock spur and pinion work
    Or is it that under powered or overpowered
    I'm looking not for speed runs but for drivining around and off roading with dirt hawgs the buggy ones
    so cal
    9,244
    If you are into hard off roading you should stick with a small block. You don't need all that extra weight and raising the center of gravity .
    153
    Ok I mean yea I'm go wanna fly down the street like a speed run but im gonna wanna go from on road to light off road the same run
