Results 1 to 10 of 10
    Arkansas
    335
    Need Gearing help
    Hi everybody. I have a MERV and I have had a lot of trouble with it so far, mostly my fault I think lol.
    So my MERV has ALOT of aluminum... upper&lower arms all around, tie rods and toe links, axle carriers, and 4 piggyback alum shocks. I also have 4 proline dirthaws on the titus wheels.
    I know I have added a considerable amount of weight to my kit. I have compensated by purchasing the traxxas 11.1v lipo. It's crazy fast... I have the high speed pinion that came with the kit installed.
    So there you know everything about my kit. But I have blown my rear diff. Only after 2-3 runs. I have heard of problems with the bulkheads becoming loose and causing the gear mesh to be bad, I think thats what happend to mine.
    Do you guys think I should change my pinion and spur gears to a lower gearing, or purchase the expensive alum bulkheads?
    Any and all advice is welcome!
    1,717
    I dont think aluminum bulks are needed. Just shim your diffs. And that is a whole lot of weight. Does your stock motor run warm?
    McKinney, Texas
    811
    Here is a thread for shimming your diff.
    http://traxxas.com/forums/showthread...-your-bulkhead
    Arkansas
    335
    Thanks! The motor did get hot to the touch once. So should get like a 14t pinion gear?
    so cal
    9,244
    You don't want to kill performance. Use a heat sink on the motor and fan on the Esc and get a buy a temp gauge to know your temps. Let it cool down once in a while
    Arkansas
    335
    Ok I'll get a heat sink, but do I need to lower my gears?
    north van canada
    528
    yes go like 19/50 or 21/50 if its still hot go up to a 55 spur
    Powered by Castle
    so cal
    9,244
    Only way to truely know is run it and check the temp with a temp gun.if you don't have one get one!
    Arkansas
    335
    Thanks man!
    so cal
    9,244
    I.tryed a fan on my motor which had a decent heatsink on it was running 150 and after the fan 110 looks good to me!
