Results 1 to 7 of 7
    12
    Can't charge traxxas nimh 5000mah :( help
    Hi
    I’ve just bough an EZ-peak plus charger and a couple of traxxas nimh 5000mah series 5, 8.4v power cell.
    I can’t manage to charge those cells correctly, after between 5 to 30m the charger bip and indicate it’s full
    When i use the battery i can only play like 5m and it’s out of power.
    Can you tell me the exact and best settings to charge this specific cells ?
    I’ve use 2 different settings without succes
    Nimh charge : auto
    Cur limit : 5.0A and 3.0A
    Nimh sensitivity D.peak . Default and 6mV/cell
    The original 3000mah coming with the vxl is working fine and i can charge it using one of those setting.
    It would be very kind of you if can give me a hand on that.
    Thanks in advance.
    u.k.
    1,471
    has it a capacity setting which is set at 3000 for the other battery and needs changing to 5000
    The message above has copyright protection. ©
    12
    that's what i've done trying first at 5mah and then 3mah thinking maybe it will help
    not working
    what about the others settings ?
    Central Florida
    555
    Charge at 1amp and see if there's a difference. How old is the battery?
    12
    they are brand new.
    do i have to discharge it first ? if so wich setting for discharging ?
    thanks
    Pittsburgh
    728
    I just bought a Traxxas charger and several NiMh batteries. The traxxas charger was false peakin all over the place, same as yours but sometimes only charging for a minute at a time.
    I charged them manually (with the included charger) and then ran them. Then charged them again. All good ever since.
    I seemed to recall that methodology from about 2004ish, the last time I had new NiMh's.
    625
    how do you discharge batterys?
