Thread: How To?
    Long Beach, California
    6,578
    How To?
    I got onther pair of trim tab and i want to know, how you guys did it without messing it up?
    thanks, Peter.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
    104
    you use a flashlight on the inside.
    El Cajon Ca
    1,804
    When you use the flashlight to locate the mounting location, you do not need to drill out the holes as there is a thin layer of plastic over the mounting holes, just use a sharp pointed object to pierce the layer of plastic since the mounting tab is already there. Start one screw and then the other.
    Hope this brief description helps.....
    "enjoy your ride"
    Dennis
    Sep 2011
    Alden, NY
    158
    Hear read this! Lol
    http://forums.offshoreelectrics.com/...cond-Trim-Tabs
    I used this and it works! Use a all or something pointed. I used the point of a ice pick. Heat it on a stove. Mark the holes with a marker. Touch the mark on your hole with the heated point and it goes right through! Carfull your only going thru a thin piece! Don't go all the way through!
    6,578
    hahahaha, i went ahead and just eyeball it with a hobby knife and got it all right on the spot.
    thanks ya'll.
