How to i adjust my ride height so that it wont be so low to the ground?
I have the KB too and the only way I've found is by tightening the suspension and it will raise the car up a bit but then you have to deal will the suspension being too tight. I'm gonna get some softer springs and a lighter shock fluid and I hope that will do the trick.
Your other option is to remove the shock limiters from inside the shocks. This will give you a higher ride height. If you are switching from dirt to road often like me, you can just have a second set of shocks without the limiters and then you can switch back and forth pretty easily.
You can drive my car, but there's a $500 deposit.
