    beverly hills 90210
    118
    Angry motor mount problem 6461
    I have a problem with this engine support 6461
    I am very disappointed by the quality 'of the material, my car is new and Already' presents problems of structure.
    The problem Arose When I tried it for the first time the machine after 5 minutes of the motor mount is loose, I have done nothing but bring the engine with the crown, I bolted the motor mount, but a screw is screwed more ', and the That screw goes into the hole of the banquet engine I can not screw it.
    I tried to do two things:
    with support included in the 6061
    screw inserted in the housing bore is idling, and if extension support from the support 6461 to 6061 I can screw it.
    the only solution is to replace the engine banquet, but this piece can not find it.
    you can help me let me know where to buy it
    thanks
    Jul 2007
    Rc Room
    1,484
    I don't follow you completely sorry.
    The Black motor end bell with bearing(banquet?) should have four threaded holes. If you stripped one out you can rotate the motor 90 degrees to use the other two holes. ? ?
    beverly hills 90210
    118
    Information about the parts I wanted a traxxas 6460.
    what I know and if 6460 is included in the spare engine support 6461 ?
    thanks
    Jul 2007
    Rc Room
    1,484
    http://www.ebay.com/sch/i.html?_from...All-Categories
    I don't think they come as one package from Traxxas but they do from Ebay. ^
    6461 http://www.ebay.com/itm/Traxxas-Moto...#ht_1629wt_826
    Post#1000
    beverly hills 90210
    118
    I asked this question, because tower hobbies sells spare 6460, I only need the 6461.
    I wanted to know if 6460 was the replacement engine 6461 also included the banquet.
    I saw on ebay that is included, tower hobbies, but I was able to respond to my question, so I wanted to know if you know
