    39
    Charging 5000 mah 3 cell
    Can someone tell me the settings that I would use.
    I have the dual charging unit too.
    Lipo balance , 5.0 A is this right for charging two battery's at once
    Or do I need to change the A to read 10.0
    Or do I need to change my 22.2 v 6s
    I am here: http://tapatalk.com/map.php?2dcwwt
    California
    4,857
    i think its a parallel adapter so it would be 3s 10,000mah. so you can set the charger at 6amps max is all it has. but verify first before doing it ok.
    DEU 8:18 ESV
    Jun 2006
    Stillwater, MN
    1,610
    I thought it was a series adapter because it has 7 wires that connect to the balance port on the charger, one positive for each cell and a negative.
    Revo.27TX/Jato.18/Maxx523/Maxx3.3/GMAXX/Rusty/ERBE
    California
    4,857
    i could be wrong johnny5c about it being a parallel connector. would make more sense if it were a parallel connector as it would be safer than a series connector but thats just me i guess.
    DEU 8:18 ESV
    Jun 2006
    Stillwater, MN
    1,610
    I've searched and can't find a straight answer, I'm probably wrong about it being series. Just thought it was series because it's a 6s charger and all 7 pins are used.
    39
    This is the way I charged these two lipos took about 85 min for 100% power . Battery's never got hot. Charger performed flawlessly.
    I am here: http://tapatalk.com/map.php?wlasx4
