Results 1 to 3 of 3
    Post tq 2.4 antennae pulled out of transmitter
    OK...so I picked up my transmitter by the antennae.....(bad habit) now the wire is not connected inside of the transmitter..... can anyone suggest how i can repair this?
    Alma, MI
    11,949
    The Tx antenna is P/N TRA2237 and is replaceable... it costs around $6.
    When you receive it, you will need to unscrew the 5 screws on the back of your remote and you will find that the antenna plugs into the circuit board that is bolted to the battery tray. With some gentle prying (with fingernails) you should be able to lift it up and then plug the new one in, route it, and then reassemble.
    If it just pulled apart, you may be able to plug it back in.
    If it ripped in two, it needs replaced.
    If it ripped off the board, you need a new remote.
    Thanks for the quick response Jimmie..!
    I figured out where it plugged into the circuit board and snapped it back in.
    ...only a few more minutes on the charger! I feel certain it will work much better now.
