Results 1 to 11 of 11
    5
    Best budget 3s lipo battery for e revo
    what is the best 3s battery that will fit into a e revo brushless I am looking at ace gens or ********s?
    any recommendatins would be greart I do not want to spend more then $60 per battery.
    Virginia
    826
    They may be a little more than your budget, but the SPC lipos are worth every penny.
    ERBE, Summit, Thunder Tiger MT4
    5
    what are the biggest ones that would fit into an erevo, are they worth spending the extra over the gens ace or ********s?
    kansas
    7,856
    This is a good start..
    Just don't buy no name Ebay batts...
    MY BATTS:
    2S 9000 x 28C = 252,000 divide 1000 = 252 amps
    2S 8000 x 28C = 224,000 divide 1000 = 224 amps
    3S 5200 x 40C = 208,000 divide 1000 = 208 amps
    2S 4700 x 25C = 117,500 divide 1000 = 117.5 amps
    ^I run in my Summit.. ^ Requires proper gearing^
    ( mah x c rating / 1000 = amps)
    The
    more amps the better / minimun of 120 amps.
    The ESC will only draw the amount of amps it needs.
    Higher the mAh the longer the runtime.
    For brushless systems 8000 mAh about 45 min & a 5000 mAh about 30 min.
    Times are longer for brushed systems.
    Batts in series double the voltage:
    2x 2s 20c 5000mah = 4s 20c 5000mah
    Batts in parallel double the mah capacity:
    2x 2s 20c 5000mah = 2s 20c 10,000mah.
    A temp gun is kind of a must have.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    Besure to check sizing before you buy any batteries...
    In time some batteries will become discontinued...
    No particular order as to good, better, or best....
    2S
    With larger Lipo battery wires, you might need to - enlarge the exit hole on battery doors....
    or run wires out the vents..
    Direct Fit...........
    2s GensAce 5000 mAh 40c
    2s Gensace 5300mah 30c softcase packs
    2s HiCountryHobbies/Billowy Power 5200 mAh 50c
    2s Hyperion 5000 mAh 45C Soft
    2s RC DUDE Power 5000 mah 35c
    2S Sky Lipo 5000 mah 40C -- fit snugly
    2s SPC 5000 mah 25C hard case
    2s SPC 5200 mAh 40C
    2s SPC 5400 mAh 50C hard case
    2s SPC 6000 mAh 30C hard case
    2s SPC 8200 mAh 30c
    2s SMC 5400 mAh 50c
    2s SMC 6000 mAh 28c
    2s SMC 8000 mAh 28C Soft Case Lipo
    2s SMC 9000 mAh 28C Soft Case Lipo
    2s SMC 9200 mAh 50C
    2s Team Orion carbon 7000 35c
    2s Thunder Power 45-90c 5000mah
    2s ******* ******** 6000mah 25-50c
    2s Traxxas 5800 mAh 25c
    2s Traxxas 7600 mAh 25c
    Mod's.............remove retainers & back out or trim screws if they extend into battery compartment
    2s SPC 8200mAh/40C
    2s ******* 30c 5000 mAh soft - Extend Batt Door Out
    2S ******* 5200 mAh 5.2 Hard Case - Trim Batt Door For Wires
    2S ******* 5000 mAh 5.0 Hard Case - Trim Batt Door For Wires
    2s ***** ********* 5000 mAh 30C hardcase
    3S
    Direct Fit..............
    3s Hyperion 5000 mAh 45C Soft
    3s Max Amps -6000xls
    3s Team Orion Carbon 4700 mAh 45C
    3s Kypom K6 6000 mAh
    3s RC DUDE Power 5000 mAh 35c snug 29mm tall
    3s HiCountryHobbies Billowy Power 5200 mAh 50c snug 28mm tall
    3s ***** 5000 mAh 30c
    3s *********x 5800 mAh 30c
    Mod's..............remove retainers & back out or trim screws if they extend into battery compartment
    3s SMC 5600 mAh 50C
    3s SMC 5500 mAh 28c
    3S SPC 5200 mAh 40C soft case
    3s SPC 5400 mAh 50C soft-case
    3s Thunder Power 3s 45-90c 5000mah
    3s Traxxas 5000 mAh 25c
    3s ******* ******** 6.0 6000 mAh 25-50c
    3s ******* 5000 mAh 30c soft - Minor Mod/Extend Battery Door Out
    4S
    4s ******* 4000 mAh 30c - Minor Mod/Extend Battery Door Out (Same size as the ******* 3s 5000mah 30c soft)
    Traxxas link to batteries
    http://traxxas.com/products/parts/ac...s-applications
    http://traxxas.com/products/models/e...less-batteries
    battery compartment:
    Charleston SC
    364
    Which Gens Ace 3s lipo are you running?
    I currently have 2) 3s ******** (4000mah 30c) but want something for speed runs.
    I was looking at the GensAce 5300 60-120c 3s. Has anyone fit this one in the e-revo? http://www.hobbypartz.com/98p-60c-5000-3s1p-3333.html
    490
    The nanos are great but keep in mind the downsides - shipping, customer support ect. The 6000 soft packs fit snug, and have a matching 2s series for 5s.
    Gens ace are great batts, but I dont know if they fit. Great packs for the price.
    Spc is my choice if you can afford them.
    Dont rule out the traxxas packs, they seem to be well built and if you factor in their warranty, they arnt actually a bad deal. Some slightly used Xo1 packs come around from time to time too...
    Charleston SC
    364
    The GensAce 5300 (http://www.hobbypartz.com/98p-60c-5300-3s1p-3333.html) doesn't look like it will fit to well. It's about .15" too wide (32.24mm). The plastic on the battery box can flex some... but it's going to be a very snug fit according to my caliper measurements
    I looked into some of the **********'s and found one that is very close to the GensAce in specs and fits with no modification to the battery tray. It is the ******* ********** 5000mah 3S 65~130C Lipo Pack. The 65c-130c will be best for top-end power and max speed correct? Or will this 6s set-up be too much power to control? I was also looking at the 5000mah 3S 45c-90.
    I looked into the SPC's and I found this one that would fit (SPC Li-Po Power, Lithium Polymer (LiPo), Soft Case Battery Pack; 5400mAh , 50C, 3S, 11.1V):
    http://www.spcracing.com/index.php?productID=131
    I'm not sure if I need the 50c or 65c in order to hit speeds of 65+mph.
    May 2010
    Silver Spring, MD
    216
    Just got a traxxas 3s 5000mah batt for $60 shipped. Best bang for your buck IMO
    33
    Here is what I have:
    1400mah 3S 40~80C Lipo Pack (TRA2823 Traxxas 1/16 models)
    Sep 2011
    Boston
    14
    Blue Lipo that Hobb partz. com carry best bang for the buck
    Quote Originally Posted by bprevo19 View Post
    Frisco, TX
    389
    Quote Originally Posted by AnthonyV View Post
    I just got these batts. I was running a 5s 25-50c setup before. So far these are pretty awesome. Unlimited power and craaazy speed. Tons of fun.
