- Forum
- Revo
- E-Revo
- My wheel wooble or slop solution with cero $$$$ freeeee... and easy!!!
I notice some wooble or slop in my revo 17mm adapters, i know that with some others brans of adapter i repaair the slop, but today i have time to play with some tools. There are the pictures, but please sorry for the bad english, if you have questions or no understand my "english" please ask me, thanks for read!!!
First i used some tools that im ready have in my garage:
-drill
-pliers or press
-7/32, 1/4, and 5/16 drills
-lubricant
-hammer
-2.0mm hex
-4 8mm nut with th same hub thread
-dub step music....
[IMG]
[/IMG]
Use the first drill and drill in the adapter until you reach the same size of th nut...about 1/8 of inch in my case. Easy because is alluminum and is very very easy for the drill. So not push harder.
[IMG]
[/IMG]
[IMG]
[/IMG]
The use the others two drills one by one with some lubricant
[IMG]
[/IMG]
Now you can see tha the hole in the adapter is close to the nut size, only the six corners of the nut are biggers
[IMG]
[/IMG]
Now is the time for the forceeeeeee
I use the hammer with little force only push the nut until is flush with the adapter
[IMG]
[/IMG]
[IMG]
[/IMG]
The final product
[IMG]
[/IMG]
Now with some lubricant screw it on the truck and put the pin
[IMG]
[/IMG]
This work GREAT for me, cero slop or wooble in my wheels, now i can use my alignment table well !!!!!
Thanks for read!!!!
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
